Author Topic: help on changing cambelt  (Read 2352 times)
trackcars
  • Merseyside
    • Omega 3.2 elite
« on: 26 May 2016, 10:36:05 »
So hopefully now I have time to do my cambelt now as really want to get it done is there any help anyone can give?
Re: help on changing cambelt
« Reply #1 on: 26 May 2016, 10:48:04 »
Buy the cambelt DVD from the Forum Shop.  :y
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #2 on: 26 May 2016, 12:26:18 »
Watch the DVD a couple of times.
Get a locking kit.
Take your time.
Ensure that you've turned the engine through at least twice so that the marks still line up.
Other things to consider before you start: thoroughly clean the front of the engine so you can check that the crank oil seal isn't leaking, if it is simple tooling is required to undo the crank bolt and remove the pulley; water pump - isn't driven by the timing belt so doesn't need to be replaced; auxiliary belt - £20 to replace whilst it's off - but definitely grease the tensioner.
trackcars
  • Merseyside
    • Omega 3.2 elite
« Reply #3 on: 26 May 2016, 14:57:08 »
Thaksn I've got the DVD from the forum shop already just need to get the campbelt and someone on here had a cambelt tool on here forsale just hope it goes all well
« Reply #4 on: 26 May 2016, 18:41:50 »
Have you asked Daz aka Darth Loo Knee or  Elite Pete? They do/did mobile fitting
trackcars
  • Merseyside
    • Omega 3.2 elite
« Reply #5 on: 27 May 2016, 09:43:54 »
No we're are they based and how much do they charge?
« Reply #6 on: 27 May 2016, 09:46:40 »
Stoke and Chester and you'll need to ask :y
Would also highly recommend Nick W, but he lives in Kent...
DrAndyB
  • The Wirral / Cheshire
    • 2.5 V6 CDX Manual (MFL)
« Reply #7 on: 27 May 2016, 20:41:28 »
Daz did mine  :y
Top Fella  :y
