Author Topic: Misfire perhaps in bank 1 this time  (Read 2928 times)
polilara
  • Finland
    • 2.6 Y26SE Elegance 2001
« on: 26 May 2016, 18:20:44 »
Hello
Yes, misfire during idling, no misfire when driving normally. No fault codes. Long term trims equal in bank 1 and bank 2. Short term trims +/-1 or zero when idling normally. When misfiring bank 1 short term trim climbs to +5 or +7 while bank 2 short term trim stays -1 or goes to -2 perhaps -3.
I changed ignition module for bank 2 some months ago due to misfire (spark plug wells full of water). Now I hope bank 1 has the problem this time. I did all the sealing actions needed to prevent water going to bank 2 wells anymore so I really hope it is bank 1 this time (I bought both ignition modules last time as they were quite sheep). What are these short term trims telling to us?
Re: Misfire perhaps in bank 1 this time
« Reply #1 on: 26 May 2016, 22:03:47 »
To undo the two bolts and pull the coilpack ::)
The trims are simply telling uce that the ecu is trying to accommodate an issue elsewhere, in this case a cylinder 1 misfire.
This will be due to one of three reasons... plug well is full of water (unlikely being the front one), plug well full of oil, and finally, failing coilpack (as bourne out by rusty cracks underneath it) :y
After all the grief with bank 2, I am surprised that you didn't at least check bank 1... Even more so when you say bank 2 was full of water ::)
polilara
  • Finland
« Reply #2 on: 27 May 2016, 04:34:45 »
Thanks for the comment
Actually last time I checked also Bank 1 for water and oil as I wanted to change all six plugs just for sure. Sorry that I did not mention it. Bank 1 was dry and clean after my cam cover change. But it was some months ago. This misfire just started one shiny day. I was thinking that perhaps electronics just can get old after 220 000 km. I will open the two bolts and perhaps even change the new coil back there if everything is dry, keep you informed.
polilara
  • Finland
« Reply #3 on: 28 May 2016, 17:33:30 »
Bank 1 coil back changed, no misfire anymore. No oil, water etc. found in plug wells (only plugs). Perhaps just age of electronics...
« Reply #4 on: 28 May 2016, 18:18:33 »
Any sign of corrosion on the base of the coilpack?
polilara
  • Finland
« Reply #5 on: 28 May 2016, 19:08:10 »
[/highlight]
I check tomorrow, wait...
polilara
  • Finland
« Reply #6 on: 29 May 2016, 14:20:03 »
Actually yes, corrosion found in those metal pieces which can be seen is small rectangular holes in the base. So, what is this all?
« Reply #7 on: 29 May 2016, 14:52:51 »
Condensation... water leaking in gets turned to steam... this then condenses on the coilpacks... over time it corrodes, and causes the layers to split... over time and with heat, these separations cause the coil to fail giving you your misfire :y
polilara
  • Finland
« Reply #8 on: 29 May 2016, 16:07:56 »
Sure, the construction is perhaps not best possible, water really can go through this stupid sealing at least when getting old. Just wondering how this is designed in newer engines e.g. Z28NET. I tried to find it out from google did not succeed. Must be better solution available. It seems that this engine really cannot be cleaned with high pressured water like engines made in 70's...
« Reply #9 on: 29 May 2016, 18:34:43 »
Well there's your problem :o
What made you think it could be :-\
polilara
  • Finland
« Reply #10 on: 29 May 2016, 18:54:25 »
No, I did not do that (cleaning it with my Kärcher) as I read somewhere that it is not recommendable. But it is a pity that you cannot do it. After 200k and after all oil leaks etc. it would be nice  to clean everything everywhere.
« Reply #11 on: 29 May 2016, 18:57:01 »
Ah ok, you can clean it but it has to be done the hard way :y
