Pages: [1] 2 3  All   Go Down
Author Topic: Diagnostics  (Read 15352 times)
Tony H
  • liverpool
  • Black Elites are luurvley
Diagnostics
« on: 27 May 2016, 18:45:17 »
Hi all can  anyone tell me if Tech 2 or for that matter any diagnostic machine will detect a dis pack fault on an Omega or other cars?
TIA
Tony
Re: Diagnostics
« Reply #1 on: 27 May 2016, 19:21:58 »
Indirectly it can help. But it won't say "The DIS/Coil pack is shagged, replace it".
On Omegas, for pre DBW cars, it will likely say no faults, even though there is a chronic misfire. In this scenario, check the HT side of things if the trims/MAF look OK.
On DBW, it'll likely suggest which cylinder is misfiring, though you still need to use common sense to ascertain if fuelling, HT or bugger engine.
Tony H
  • liverpool
Re: Diagnostics
« Reply #2 on: 28 May 2016, 19:53:26 »
Had a miss fire for a while now. lumpy idle, no miss on slow acceleration, misses on moderate acceleration, floor it and the miss clears, but when the throttle is backed off the miss reappears. New plugs and leads fitted seems to improved a bit but still missing any advice would be greatly appreciated. P.S. could this be caused by a faulty dis pack?
« Last Edit: 28 May 2016, 20:02:17 by Tony H »
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Diagnostics
« Reply #3 on: 28 May 2016, 20:23:22 »
Posting your Engine Type and Year might help together with any Fault Codes.
  • Auckland
    • Mazda MPV
Re: Diagnostics
« Reply #4 on: 28 May 2016, 20:36:47 »
On cars with one coil per plug (ie facelift Omegas) the diagnostics can often be used to switch off individual coils to aid diagnosis. I think Tech2 can do this  :-\
Tony H
  • liverpool
Re: Diagnostics
« Reply #5 on: 28 May 2016, 22:33:27 »
2.5 2000  :y
zirk
  • Epping Forest
Re: Diagnostics
« Reply #6 on: 29 May 2016, 01:10:00 »
2.5 2000  :y
omegod
  • liverpool
    • 2017 Seat Ateca
Re: Diagnostics
« Reply #7 on: 29 May 2016, 09:17:17 »
Hi Tony, I recall my 3.0 behaved like this when the DIS pack was on it's way out , I have diagnostic stuff and am in Huyton but work most weekdays in Bootle if you want it plugging in, as TB says it may record a misfire but not much else :-\  give me a shout, Jon
Tony H
  • liverpool
Re: Diagnostics
« Reply #8 on: 29 May 2016, 16:18:03 »
P.M sent  :y
Tony H
  • liverpool
Re: Diagnostics
« Reply #9 on: 30 May 2016, 20:51:00 »
2.5 2000  :y
Had a local garage plug it in to his machine I don't know what type or how good it is but it was not a Tech 2. I came up with three fault codes a transmission an 02 sensor an one more that I can't remember but the bloke said it would not cause a miss fire.
  • Auckland
    • Mazda MPV
Re: Diagnostics
« Reply #10 on: 30 May 2016, 22:31:16 »
2.5 2000  :y
You can use the paperclip test on your engine Paperclip test & pedal trick to read the codes but I don't think that ECU is capable of telling you much about the ignition or misfires.
I had a misfire on a 2.5 several years ago. After dicking about getting the codes read and looking for a complex cause I did some basic maintenance - I changed the spark plugs - that fixed it :y
Tony H
  • liverpool
Re: Diagnostics
« Reply #11 on: 30 May 2016, 22:46:30 »
Thanks for your reply Andy  :y, but as stated new leads and plugs fitted but has not fully cured the problem.
Diamond Black Geezer
    • & a silly coupe coming...
Re: Diagnostics
« Reply #12 on: 31 May 2016, 09:09:25 »
Never forget that more than one thing can be the cause of a problem. I've found that in the past with a poor idle, it was three separate things which were causing it. Hope you get sorted soon :)
Re: Diagnostics
« Reply #13 on: 31 May 2016, 14:36:34 »
Right well the Motronic 2.8.1 setup on the 2.5 wont detect a misfire.
To test the DIS pack you need a test plug with a 35-40mm gap, then its dead easy to do as they can all be checked using the 1-3-5 bank leads which are easy to get to.
I suspect the lambda fault is as a result of the misfire.
The symptoms described point towards the ignition setup as max volts are needed from the DIS at lighter throttle openings.
Re: Diagnostics
« Reply #14 on: 31 May 2016, 18:43:28 »
I too would be going with deeper investigation into HT side...
Pages: [1] 2 3  All   Go Up
