Brake Pad Wear Warning Message
Started by amba, 29 May 2016, 14:43:54
terry paget
I wonder if the brake fluid level switch can become unreliable when old, as do header tank switches and washer fluid switches. Have you swopped it for a spare?
amba
Thats a good call Terry. :y
Will have a look when I get a few spare minutes  ;)
Just to clarify, the brake fluid level switch when low fluid throws up a warning light on the dash and has nothing to do with the low pad message in the message centre which is triggered by the brake pad wear sensor, or a fault in its wiring. ;)  HTH
