Pages: [1] 2 3  All   Go Down
Author Topic: Pre -FL 3.0 no start..  (Read 16115 times)
philhoward
  • Staffs
  • Love the engines, so put one in something else..
« on: 29 May 2016, 18:52:41 »
Now this is a previously running engine (although not in an Omega now).
It started misbehaving a while ago - would start then stutter and stall.  I've changed the fuel pump (twice) and the crank sensor (twice - one genuine, one pattern) but still nothing.  I appear to have fuel (plugs smell a little after repeated cranking) so I assume I've got signal to fire the injectors.
Paper clip test shows an O2 sensor (bank 2 - is that offside or near side?), 31 (to be expected when not running) and 57 Idle Air Control voltage low.  Still won't start if I give it a bit of throttle. Is it just the ISCV duff or a clue to something else?
Any clues welcome..
Running an X30XE in a Reliant Scimitar GTE as I can't have an Omega as a company car...
Re: Pre -FL 3.0 no start..
« Reply #1 on: 29 May 2016, 18:55:27 »
Bank 2 is the 246 side :y
philhoward
  • Staffs
« Reply #2 on: 29 May 2016, 19:15:00 »
Makes perfect sense!
Bojan
  • Croatia, Slavonski Brod
    • MV6 3.0
« Reply #3 on: 30 May 2016, 07:59:49 »
Won't start if you give it a bit of throttle  or if you don't give it?
philhoward
  • Staffs
« Reply #4 on: 30 May 2016, 08:01:40 »
No throttle or some throttle - no joy either way  :-[
I did wonder if the ISCV was duff it still might fire with a little throttle - not even a cough though.
Bojan
    • MV6 3.0
« Reply #5 on: 30 May 2016, 08:10:01 »
Any luck if you give it a full throttle?
Do you have spark when cranking?
I pressume that you don't have access to diagnostics tool?
philhoward
  • Staffs
« Reply #6 on: 30 May 2016, 08:22:36 »
I did try full throttle but assumed that was "flood clear" mode so didn't expect that to work.
Will check again for spark (had spark before I think) although didn't check yesterday.
philhoward
  • Staffs
« Reply #7 on: 31 May 2016, 19:51:51 »
Not sure if it's a red herring or not but the ECU light goes out after a few seconds of cranking - in the past its stayed lot if there was a major problem.
« Last Edit: 31 May 2016, 19:59:15 by philhoward »
Bojan
    • MV6 3.0
« Reply #8 on: 01 June 2016, 07:07:58 »
This engine is in other make of car now, right?
Was it running after it was installed?
Have you found out if there is a spark?
philhoward
  • Staffs
« Reply #9 on: 01 June 2016, 08:12:35 »
Yes, it has been running in its new home for 3 years.
Spark tester is on its way - as soon as it arrives I'll be checking for sparks.
« Reply #10 on: 01 June 2016, 21:54:33 »
Does it still have the original relays? If yes, check both small purple relays for any signs of scorching... if in doubt swap for known working ones to confirm... one powers the pump, second powers the injectors :y
philhoward
  • Staffs
« Reply #11 on: 01 June 2016, 21:56:48 »
Done both relays - even bypassed the pump one "just in case"..and happily heard fuel (and got 3 bar pressure according to my gauge) flowing through.
« Reply #12 on: 01 June 2016, 22:00:09 »
Where was the 'genuine' crank sensor from?
And Autovaux/ebay isn't the correct answer... ::)
philhoward
  • Staffs
« Reply #13 on: 01 June 2016, 22:15:32 »
Crank sensors - ah yes.
I have (from a friend who isn't running Motronic anymore) one Bosch and one Siemens sensor (both rounded plug versions).  I think he got them from Vauxhall but might have been elsewhere.  They are genuine though - he wouldn't have spent c.£80 a piece on junk ones.  He bought them trying to find an issue that turned out to be his shiny new ECU, not the crank sensors after all.
Anyway - have tried both and a £20 eBay cheapie (worked last time proving another fault).  Same result - no start :(
If it's any use, I'll get the numbers off the actual sensors - I have a feeling the one should only be fitted to a specific 2.5 variant?
« Last Edit: 01 June 2016, 22:32:29 by philhoward »
« Reply #14 on: 02 June 2016, 09:15:12 »
There is an issue that has cropped up with the 2.5 in the past, that the sensors are different lengths. Some appear to have a shorter nose than others and don't reach the reluctor ring on the crank to get a reliable signal.
Do you have access to an oscilloscope? Just wondering if you can check the output from the sensor?
Pages: [1] 2 3  All   Go Up
