Author Topic: DIY Air-Con Diagnosis  (Read 2081 times)
Scatmancraig
  • Skellingthorpe, Lincolnshire
« on: 09 June 2016, 06:10:29 »
Hi,
My Omega 2.5 TD CDX air-con isn't working.  No surprise there, especially as it doesn't appear to have any gas in it  >:(.  As far as I see, the system is complete though, so it could have justlostall the gas over time.  Are there any DIY checks I can do to see if the system would work before I go to the expense of attempting to have it gassed up?  I'm particularly worried about it having a massive leak somewhere, is there a DIY leak test?
Re: DIY Air-Con Diagnosis
« Reply #1 on: 09 June 2016, 06:50:57 »
Apparently 10% gas loss year on year is acceptable, but most likely to be a rotten condenser...
Easiest, and only real way to check is to have it regassed.
Make sure they use a dye when they do it. If it works, happy days, if it doesn't then the dye will help find the hole(s) ;)
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #2 on: 09 June 2016, 09:00:14 »
Take it to a reputable place who will pressure test the system with nitrogen, after it's been on the Dalek. As a Dalek only tests if it will hold a vacuum.
It needs to be able to hold pressure for 1/2hour then be re-vacuumed have dye put in then checked again then regassed. :).
Hoof'land storeman.
« Reply #3 on: 09 June 2016, 11:28:14 »
Do inspect the bottom of the condenser first though as its probably fallen off, far better to replace this first saving a repeat visit.  :y
biggriffin
« Reply #4 on: 09 June 2016, 12:25:46 »
Plus1, as above. :)
Hoof'land storeman.
Scatmancraig
« Reply #5 on: 09 June 2016, 20:47:41 »
Sounds like top advice from everyone. Long way to go before I start sorting air-con issues out, but at least I know where I'm heading!!
