Author Topic: Undertray  (Read 3917 times)
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
Undertray
« on: 09 June 2016, 21:31:47 »
How many bolts/screws hold this on and what size/type are they.Thinking for dropping this off to empty coolant without dumping it all over the floor.
Re: Undertray
« Reply #1 on: 09 June 2016, 21:59:50 »
Only 4 bolts, about 10mm, if memory serves. :y
BazaJT
Re: Undertray
« Reply #2 on: 09 June 2016, 22:03:01 »
Fair enough,thanks for that :y
flyer 0712
Re: Undertray
« Reply #3 on: 09 June 2016, 23:46:44 »
Yep  :y :y :y :y
Re: Undertray
« Reply #4 on: 10 June 2016, 11:51:24 »
8mm, but, as above... only four of them :y
Expect a face full of muck as you drop it :D
That said, to drain the coolant, you don't need to drop it...
Get the car hot, with heater on Hi (fan on lowest setting).
Turn full left lock.
Drain plug sits on lower left hand end of rad and is accessible from wheel arch.
Place washing up bowl under the drain spigot.
Slowly undo header cap.
Open drain screw carefully, a half to full turn should do it.
Check coolant is draining into bowl.
Go and have a cuppa.
Refilling:
Close drain plug.
Pour 5 litres of neat GM coolant into header tank.
Top up with distilled water upto max mark.
Leave cap off.
Start car.
Set heater to Hi, (fan on lowest speed).
When radiator fans kick in, burp the top hose 4/5 times.
Top up to max with distilled water.
Refit cap.
Job done.
Re: Undertray
« Reply #5 on: 10 June 2016, 16:29:12 »
Ahh drain plug. That reminds me. Small patch of dead grass where mine ends up parked. ::)
BazaJT
Re: Undertray
« Reply #6 on: 10 June 2016, 20:36:41 »
May be just me but I've always been a bit wary of disturbing things like drain taps,so was going to drop undertray to get at bottom hose.Might give drain tap a go though as it sounds easier/quicker and with my luck what could possibly go wrong :D ;D ;D
Re: Undertray
« Reply #7 on: 11 June 2016, 00:48:29 »
Yes, partly why mine hasn't been fixed. Messing with it could make it much worse!
I wonder what size O rings it needs?
BazaJT
Re: Undertray
« Reply #8 on: 11 June 2016, 06:00:42 »
Seem to recall that someone did a thread or contributed to someone elses thread not so long ago with regard to drain tap O rings[complete with pictures too]but I'm not clever enough  with computers to find it.
  • Auckland
    • Mazda MPV
Re: Undertray
« Reply #9 on: 11 June 2016, 07:55:35 »
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
Re: Undertray
« Reply #10 on: 11 June 2016, 08:00:14 »
p13 lst post 25march16. Try thishttp://www.omegaowners.com/forum/index.php?topic=135061.0
terry paget
    • 3 Astras 2 Vectra
Re: Undertray
« Reply #11 on: 11 June 2016, 08:01:15 »
  • Auckland
    • Mazda MPV
Re: Undertray
« Reply #13 on: 11 June 2016, 10:20:01 »
Thanks, Guys!
.. and sorry for the thread hijack. :-[
BazaJT
Re: Undertray
« Reply #14 on: 11 June 2016, 16:10:57 »
I for one have no problem with you hijacking thread as it may very well prove useful to me too :y
