Author Topic: Brakes question Omega 2.0 CD 2000 x reg  (Read 6214 times)
Jazzyj123
  • Hemel Hempstead
    • Saab 9-5 2.3t Vector
« on: 18 June 2016, 19:46:23 »
I've gotta change the brakes on my dad's vauxhall omega (as above) and I'm trying to order the pads and discs but apparently there's 2 different types of calliper and brakes. How on earth do I find out which kind I need?
andyc
  • Norfolk
Re: Brakes question Omega 2.0 CD 2000 x reg
« Reply #1 on: 19 June 2016, 09:56:37 »
Can't remember the chassis break point but unless its a 2.0 8valve or a very early 2.0 16v then they are all the same, what year is your car?
Andy
Thetford. Norfolk
Jazzyj123
  • Hemel Hempstead
« Reply #2 on: 19 June 2016, 10:02:38 »
It's a 2000 x reg vauxhall omega. One of the first full facelift models. Apparently there are lucas type callipers and Teves type or something?
frostbite
  • Roanapur City aka Skem
    • 00' e46 325i se
« Reply #3 on: 19 June 2016, 16:52:43 »
The discs should be 280mm
The pads will need checking mine have the wider pad the the wings on each side. My old 2.5 cdx had the 296mm and the shorter pads
Lucas/ Girling  use the longer pads with wing shaped guides
Teves are the shorter style
Where are you buying from?
« Last Edit: 19 June 2016, 16:55:50 by frostbite »
e46 325i se - 1.8vvti avensis liftback
DrAndyB
  • The Wirral / Cheshire
    • 2.5 V6 CDX Manual (MFL)
« Reply #4 on: 19 June 2016, 17:09:10 »
I got a "Brake Kit" from the Dealer.
Genuine GM, and comes in a big HEAVY box with Discs and Pads :y
Was a bit more more than after market ones, but not that much more and worth the extra few quid to make sure GM Genuine  :y
« Reply #5 on: 19 June 2016, 17:17:37 »
It will have 296mm front discs.  Pads are around £15 for GM Tradeclub ones.  GM discs and pads are around £90.  In both cases, sensors are extra (about £7 for GM on tradeclub)
Jazzyj123
  • Hemel Hempstead
« Reply #6 on: 19 June 2016, 17:23:34 »
Our local dealer say that the trade club only gets you discounts on parts that are fitted by them not stuff you buy to take away
« Reply #7 on: 19 June 2016, 17:30:47 »
Quite of opposite. Assuming they are a TC dealer of course, not all dealers are.
Jazzyj123
  • Hemel Hempstead
« Reply #8 on: 19 June 2016, 17:40:34 »
Ahhh I see. Either way we can't quite afford £90. What's the best place to get oem quality pads and discs from?
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #9 on: 19 June 2016, 17:52:47 »
Front discs and pads are about £70 at Eurocarparts.
Jazzyj123
  • Hemel Hempstead
« Reply #10 on: 19 June 2016, 17:53:55 »
Yeah I saw those. What are the eicher ones like or are they crap?
« Reply #11 on: 19 June 2016, 18:11:58 »
I have tried a fair few in an effort to save a few pennies, and they are all universally shite, both in performance and disc durability.
Hence, I can only ever recommend the TC (or OE) stuff.  TC is generally near OE quality at aftermarket prices.
Jazzyj123
  • Hemel Hempstead
« Reply #12 on: 19 June 2016, 18:17:46 »
Fair enough. Will have to go with cheap ones for now and see what they're like. He doesn't do a lot of spirited driving so they should be fine.
  • Chatham, Kent
« Reply #13 on: 19 June 2016, 19:34:52 »
Don't know yet, the only ones I've used have been on the back of sister's Hyundai for a month which is hardly a test. It's the pads that matter; I won't buy Apec for instance as even with my gentle driving faded to useless in three hard stops.
I have about 1/4million miles in various vehicles using  Pagid parts with no issues.
Jazzyj123
  • Hemel Hempstead
« Reply #14 on: 19 June 2016, 19:57:48 »
Hang on I know why. I've only got service club account as I can't get a trade club account.
