Author Topic: Replacement remote locking key fob case needed  (Read 8985 times)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Replacement remote locking key fob case needed
« Reply #15 on: 07 July 2016, 11:49:05 »
Just like to say thanks to tigers_gonads for his help, I now have a much better key fob than I had before, it even still has the little symbols on the rubber buttons!
So now I have a fully working fob.  I've even discovered how to close the windows and sunroof from the fob too (press and hold the close button), and how to deadlock the doors (press close button once to lock doors, and again to deadlock).
Happy days!  ;D
Excellent, all you got to do now is work out how to get back in.  ;)
Diamond Black Geezer
    • & a silly coupe coming...
« Reply #16 on: 15 July 2016, 10:59:19 »
He's one of the good ones, is Steve, don't believe the rumours :y
Fabianknutsen
  • Norway
    • Opel Omega 2.5 v6
« Reply #17 on: 09 January 2017, 20:03:31 »
Did you find out if its possible to buy them somewhere new ?
spanish_lad
  • spain
    • 1995 25XE saloon
« Reply #18 on: 20 January 2017, 07:39:47 »
you can buy from eBay / aliexpress for a couple of pounds, but you might need to sand / file the edges (refinishing) to get the fit perfect.
if i hear "its dealer only" one more time im gonna set fire to the mig :p
kwhite@fsmail.net
  • York
    • 2002 2.6 CDX
« Reply #19 on: 13 February 2017, 11:33:20 »
If it helps, I can recommend this guy on fleabay..
http://www.ebay.co.uk/itm/For-Vauxhall-Vectra-Omega-Signum-2-3-Button-Remote-Key-Fob-REPAIR-SERVICE-FIX-/390245877358?hash=item5adc77866e:g:k4UAAMXQwKdRbltk
having just had one of my keys re-built.  Just sent the whole thing in an envelope and it came back within a week and worked straight off the bat.  Not as cheap as doing it yourself obviously but was simple and quick.
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #20 on: 14 February 2017, 20:40:06 »
Or buy the cover from him for £3 and spend 5 minutes swapping the parts over yourself.  ;)
kwhite@fsmail.net
  • York
    • 2002 2.6 CDX
« Reply #21 on: 21 February 2017, 16:03:29 »
True, but I tried that once years ago and there seemed to be too many (3 button) versions so I took the lazy route this time!
Update: the fob has come away from the shaft bit a couple of times as I take the key out of the ignition but hopefully just needs a bit of force to get them to stay together.  ???
