Author Topic: 2 front fans  (Read 2964 times)
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
2 front fans
« on: 21 June 2016, 20:20:13 »
Passenger side one isn't working, I originally thought that both only come on if the engine gets too hot, But have since noticed the other car when the A/C is on both are on.
What tends to be the usual reason behind why the fan wouldn't work? As far as I can see they are all plugged in.
Re: 2 front fans
« Reply #1 on: 21 June 2016, 20:25:17 »
Blown fuse would be a good starter for 10
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
Re: 2 front fans
« Reply #2 on: 21 June 2016, 20:29:03 »
Aye, Did think that also but haven't a clue which fuse it would be, Do you happen to know which fuse it is for the passenger front fan?
Re: 2 front fans
« Reply #3 on: 21 June 2016, 20:30:04 »
from memory, one of the big green ones in relay box
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
Re: 2 front fans
« Reply #4 on: 21 June 2016, 21:15:47 »
Their both working, Jiggling about the higher up green one kicked it back into life. Will look into a new or a good used one in case it decides to not work again.
Re: 2 front fans
« Reply #5 on: 22 June 2016, 01:44:15 »
They can stick occasionally, especially if the Aircon isn't used... Can be partially stripped and lubricated, but easiest to do when condenser is being changed due to the way they are mounted ;)
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
Re: 2 front fans
« Reply #6 on: 22 June 2016, 19:10:18 »
Good to know  :y
I use the A/C all the time myself, Prehaps the previous owners didn't or its just ware an tear with the 204k miles. Still working so far anyway.
