Avon leak in car
Started by Kieran, 23 June 2016, 15:12:25
The normal expansion valve failure mode is for it to fail closed meaning little or no cooling, normal pressures around the system but no leaks. Clearly something is leaking in the cabin in this case, mind.
jimbo125
Quote from: Kieran on 23 June 2016, 18:47:56
That may be the cause as from looking on this site evaporators rarely fail. Really need to know how to access it. Suppose that failing would cause a leak into the cabin.
Nor do HGs on V6s but it happened to mine ;D ;D ;D
2.5V6 Had it since 2002, what a beast, worth the time and effort to keep it road worthy. Vauxhall bring them back!!! Laser timing kit for OOF member hire
Quote from: jimbo125 on 24 June 2016, 15:01:39
Nor do HGs on 3.2 V6s but it happened to mine which is a 2.5 ;D ;D ;D
Fixed ::)
frostbite
That's funny
I had mine regassed a few weeks ago and I got a funny smell in the cabin smelt like natural gas and got a whiff every so often. It's stopped now so I'll see if it stays cold
e46 325i se - 1.8vvti avensis liftback
jimbo125
Once your A/C is working you blow cold dry air through the ducts, could the smell be the damp ducts drying out as the dry air removes residual water and any funny wiffs with it? :y
frostbite
Quote from: jimbo125 on 25 June 2016, 13:16:19
The ac worked but wasn't as cold as it is now,  was just strange that it happened after regassing
jimbo125
Hopefully just a red herring but best of removing it anyway can smell in the hot weather ;D ;D ;D
