Author Topic: Evaporator  (Read 2547 times)
Kieran
  • Dorset
Evaporator
« on: 24 June 2016, 09:56:21 »
Leading on from my Aircon problem. Must be the pipes leading into the evaporator. How can you access these pipes under the dash, is it a dash out job. Garage saying 6.5 hour job plus parts. Car is a 2.6 Estate.
Regards
Kieran
  • Dorset
Re: Evaporator
« Reply #1 on: 24 June 2016, 09:57:03 »
Also gas leaking into cabin.
Re: Evaporator
« Reply #2 on: 24 June 2016, 10:22:06 »
Could leave it degassed and simply press the Eco switch... 6.5 hours sounds on the light side for dash out imho, that said, get the quote in writing as I suspect it could end up being twice that :-\
Kieran
  • Dorset
Re: Evaporator
« Reply #3 on: 24 June 2016, 11:20:42 »
Yes could do but really need it fixed. Really need to know how to get to the evaporator.
Re: Evaporator
« Reply #4 on: 24 June 2016, 12:27:56 »
I doubt the whole dash has to come out.
Remove the glove box, passenger airbag, blower fan and ducting and a few other cable trays and things and you can certainly get to the end of the evaporator and the expansion valve. Whether there's room for it to come out, I can't say, but it's possible the leak isn't the evaporator itself but one of the connections to it or the expansion valve.
