Author Topic: Throttle Cable  (Read 1316 times)
Throttle Cable
« on: 30 June 2016, 13:46:16 »
So I was going to change my cam cover gaskets today for the upteenth time, but I cannot remove the throttle cable ball joint!  >:(
I've pulled the pin and have been trying to free it but it won't budge and I'm making very little progress.  :(  I've always found it to be a bit of a PITA but have always managed it before.  ::)
What am I doing wrong?  ???  ::)
TIA from a very pissed off and frustrated Sir Tigger!  :y
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Throttle Cable
« Reply #1 on: 30 June 2016, 13:56:47 »
When you do get it apart I suspect that there will be a wear ridge on the connector that is holding it together. This will have been caused by dirt mixing with whatever lubricant had been applied making a weak grinding paste.
Give it several copious squirts of brake cleaner while rotating the connector.
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Throttle Cable
« Reply #2 on: 30 June 2016, 14:16:14 »
Re: Throttle Cable
« Reply #3 on: 30 June 2016, 14:32:40 »
That's crossed my mind....  ::)
