Pages: 1 [2] 3  All   Go Down
Author Topic: MV6 spec  (Read 9127 times)
Re: MV6 spec
« Reply #15 on: 04 July 2016, 14:53:22 »
Terry have you "asked seller a question" about the lack of mot
The following should be the answer...
Test date: 1 July 2016
Test Result: Fail
Odometer reading: 83,016 miles
MOT test number: 1319 6090 0966
Reason(s) for failure: rear Brakes imbalanced across an axle Axle 2 (3.7.B.5b) nearside front Steering component mounting prescribed area is excessively corroded chassis rail at steering idler mount (2.2.C.1h) offside front Steering component mounting prescribed area is excessively corroded chassis rail at steering idler mount (2.2.C.1h) nearside outer Ball joint has excessive play track rod end (2.2.B.1f) offside Rear wheel bearing rough when rotated (2.6.1) nearside front Tyre tread depth below requirements of 1.6mm (4.1.E.1) offside front Tyre tread depth below requirements of 1.6mm (4.1.E.1)
Advisory notice item(s): offside outer Ball joint has slight play track rod end (2.2.B.1f) front brake disc worn, pitted or scored, but not seriously weakened both heavy rusted on inner faces (3.5.1i) offside rear brake disc worn, pitted or scored, but not seriously weakened (3.5.1i) Windscreen has damage to an area less than a 40mm circle outside zone 'A' (8.3.1d)
Be a good breaker :-X
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
Re: MV6 spec
« Reply #16 on: 04 July 2016, 16:41:32 »
Yes, he said it expired that day (last Thursday).
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
Re: MV6 spec
« Reply #17 on: 04 July 2016, 18:54:37 »
Sounds like the front chassis is as rotten as a pear. As Dr. Gollum says, it would make a good breaker. But probably not worth the money effort & time as a car for the road. Unless its being almost given away.
terry paget
    • 3 Astras 2 Vectra
Re: MV6 spec
« Reply #18 on: 04 July 2016, 19:32:12 »
Quite so. Thanks Dr. Gollum. I did not know anyone could examine MOT failure data. That settles that.
Re: MV6 spec
« Reply #19 on: 04 July 2016, 19:41:29 »
£350+ isn't give away money...
MoT history check link...
https://www.gov.uk/check-mot-history :y
pauls
  • By the sea minehead
    • Bmw x3
Re: MV6 spec
« Reply #20 on: 04 July 2016, 19:42:38 »
just put in car reg and make of car. It goes back to 2006 i think :y
Beat me to it ;D must type faster
Mr Gav
  • Leeds
    • Nissan 370z GT Edition
Re: MV6 spec
« Reply #21 on: 04 July 2016, 20:37:21 »
And don't forget the ecu let's you play a bit more before the traction control kicks in  :y
Dont understand that one. :-\
The ECU is programmed slightly different to the Elite according to 2woody, the traction control allows a bit more slip before stopping play than it does with the Elite.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: MV6 spec
« Reply #22 on: 05 July 2016, 07:11:55 »
More than I would pay to break it.
Hoof'land storeman.
amba
  • Medway towns
    • German V6
Re: MV6 spec
« Reply #23 on: 05 July 2016, 08:12:51 »
Reading the past history,that has not been a "well loved car"...best avoided imho
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: MV6 spec
« Reply #24 on: 05 July 2016, 13:49:44 »
Test Result: Fail
No Mot, with the above Fails, Cost to Trailer it, and 350 quid, not worth taking it on, unless you specifically need it for spares.
biggriffin
Re: MV6 spec
« Reply #25 on: 05 July 2016, 18:02:24 »
Relisted..  ???.
Hoof'land storeman.
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
Re: MV6 spec
« Reply #26 on: 05 July 2016, 18:18:37 »
At least you can see the MOT history. Always jars me off when sellers obscure the reg so you can,t check. Always makes me think they have something to hide. ???
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
Re: MV6 spec
« Reply #27 on: 05 July 2016, 21:24:52 »
MV6 spec is far, far superior to any other spec. But I would say that...
I much prefer the fake ally to the fake wood - so much so that I've painted the trim in my explod...!
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
Re: MV6 spec
« Reply #28 on: 05 July 2016, 22:17:55 »
The fake wood says "old mans car" and the fake alloy isn't fake...Its real  :-X
zirk
  • Epping Forest
Re: MV6 spec
« Reply #29 on: 06 July 2016, 00:26:33 »
The early MV6's had Carbon Fiber trim on Consul and Doors, but alias it was fake Plastic Molding.
The latter MV6's had Titanium Metal trim on Consul and Doors, but alias it was fake Plastic Molding painted silver.
Pages: 1 [2] 3  All   Go Up
