V6 cam covers
Started by Webby the Bear, 06 July 2016, 19:09:43
Webby the Bear
Yep deco none in garage. Anyone got any for sale or worth a wanted ad?
RIP Paul Lovejoy
BazaJT
Always worth a try to post up a wanted ad.I did whenI needed some,although in my case I had only one reply and that was for 2.6 items.I bought them regardless as I'm not that fussed over originality,so my ad worked for me.
ffcgary1
£126+vat i was quoted today for the plug lead type. 48 hour factory order only.
Jaguar XJ6
minifreek
I believe the metal inserts are there to stop the bolts from pulling through the plastic covers themselves...
The plastic covers are a bad design, as the holes where the bolts go through don't bottom out and when they are tightened down they flex the plastic covers, thus making them warp and leak....
I have had no problem with leakage since fitting the aluminum Vectra covers...
D.I.L.L.I.G.A.F...
ffcgary1
have you got a pic of the near side alloy cover and oil filler in perticular.
Jaguar XJ6
trackcars
I got mine from Vauxhall £52 for the left side and £70 for the right side got new gaskets from Vox and they seem to be doing fine. Took around 2-3 hours to do properly and I've got LPG pipes to move as well. Local garages wanted upwards of £350
