Pages: 1 [2] 3  All   Go Down
Author Topic: ncdr2013 plug in & play? and rear brake disc backing plates?  (Read 13574 times)
Re: ncdr2013 plug in & play? and rear brake disc backing plates?
« Reply #15 on: 12 July 2016, 09:21:09 »
Also, if the car was recently aquired from the Kings Lynn area, I would be more concerned about welding up the front of the chassis than messing with the radio...
it is said car from kings lynn, have no idea what youre on about welding up the front end???? it went straight through its mot
Very surprising seeing as this was the first result ???
Test date: 1 July 2016
Test Result: Fail
Odometer reading: 83,016 miles
MOT test number: 1319 6090 0966
Reason(s) for failure: rear Brakes imbalanced across an axle Axle 2 (3.7.B.5b) nearside front Steering component mounting prescribed area is excessively corroded chassis rail at steering idler mount (2.2.C.1h) offside front Steering component mounting prescribed area is excessively corroded chassis rail at steering idler mount (2.2.C.1h) nearside outer Ball joint has excessive play track rod end (2.2.B.1f) offside Rear wheel bearing rough when rotated (2.6.1) nearside front Tyre tread depth below requirements of 1.6mm (4.1.E.1) offside front Tyre tread depth below requirements of 1.6mm (4.1.E.1)
Advisory notice item(s): offside outer Ball joint has slight play track rod end (2.2.B.1f) front brake disc worn, pitted or scored, but not seriously weakened both heavy rusted on inner faces (3.5.1i) offside rear brake disc worn, pitted or scored, but not seriously weakened (3.5.1i) Windscreen has damage to an area less than a 40mm circle outside zone 'A' (8.3.1d)
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #16 on: 12 July 2016, 09:35:08 »
Test Result: Fail
Hence why it appeared as an auction and not a for sale.  ::)
Hoof'land storeman.
omegaelitetd
  • bedfordshire
    • omega 2.5td elite
« Reply #17 on: 12 July 2016, 09:43:17 »
no i bought it with no mot and didnt know it had been for one else where previously. ive since had it mot'd at a garage near me who passed it and before anyone asks no it wasnt a bent ticket either. perhaps it went to a mot testing station such as kwik fit or similar who was trying to find work it didnt need i dont know aint the first time ive had that in the past certain garages failing it on stuff it didnt need in the first place.
« Reply #18 on: 12 July 2016, 10:31:42 »
Brake imbalance and steering component chassis mounting corrosion are not subjective items :-X
I didn't make a note of the listing, so have no reg for running the latest MoT... but would have thought that the brake imbalance would have constituted a dangerous fault :-\
amba
  • Medway towns
    • German V6
« Reply #19 on: 12 July 2016, 11:11:55 »
Also looking at the past Mot history it had been flagged up every year,suggesting problems had never been resolved although not failing on
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #20 on: 12 July 2016, 11:21:18 »
That could be true, but if I had just bought it I would give it a close inspection on the areas mentioned above.  ;)
omegaelitetd
  • bedfordshire
    • omega 2.5td elite
« Reply #21 on: 12 July 2016, 11:33:34 »
once ive sorted the rear brakes etc out im planning on fitting new front discs + pads on it anyway aswell as 2 new front tyres as they are low so i'l be having a good look at these areas anyway.
Migv6 le Frog Fan
« Reply #22 on: 12 July 2016, 11:41:50 »
Might be best to have a look before you spend more money on it ?
biggriffin
« Reply #23 on: 12 July 2016, 12:17:00 »
There's a rumour, that the mot testers dog was very friendly  ;D
Hoof'land storeman.
« Reply #24 on: 12 July 2016, 13:06:12 »
Chassis corrosion is very speculative in my experience, you see some pass areas of corrosion and others fail it.
As for back plates, according to my tame man they are still available but have to come from Germany so a few days wait.
On the NCDC displays, the (rare) Astra G ones will work with the Omega if that helps (fitted two of these myself) but there is a mode pin you need to set to get them to program ok. Other wise its a case of add a few extra wires to the loom for the RGB signals etc and move a couple of pins around, easy enough to do.
omegaelitetd
  • bedfordshire
    • omega 2.5td elite
« Reply #25 on: 12 July 2016, 13:31:07 »
is the back plates from vauxhall? as ive already tried them and they said no longer stocked??
« Reply #26 on: 12 July 2016, 13:48:59 »
Yes from Vx
Try calling another dealer as you have probably hit upon one who cant be arsed to look at stock in the other dealers or central stock  :y
Part codes are 24436738 and 24436739
As an example, there are a pair on German ebay for circa €86 delivered
http://www.ebay.com/itm/2x-ORIGINAL-GM-Opel-Abdeckblech-Bremsankerblech-OMEGA-B-hinten-24436738-24436739/182169202654?_trksid=p2045573.c100033.m2042&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D37468%26meid%3Deb7ed36bc00b45638545b01a4da9d2af%26pid%3D100033%26rk%3D1%26rkt%3D8%26mehot%3Dlo%26sd%3D182169202654
omegaelitetd
  • bedfordshire
    • omega 2.5td elite
« Reply #27 on: 12 July 2016, 16:13:30 »
Yes from Vx
many thanks ive just ordered these.
Migv6 le Frog Fan
« Reply #28 on: 12 July 2016, 17:30:49 »
Which model of the Astra G range would have had an NCDC 2013 / CID fitted ?  :-\
« Reply #29 on: 12 July 2016, 20:09:04 »
Think Mark means the CID, rather than the entire set up, but will be pretty rare as the NCDR1100 with CID was probably a £900+ option...
Usual caveat also applies re depairing properly or risk bricking it ;)
Pages: 1 [2] 3  All   Go Up
