Author Topic: Vauxhall badge (writing)  (Read 5414 times)
Omegadone
    • 2 mv6s
« on: 13 July 2016, 18:45:40 »
Hello just wondering if someone could point me in the right direction to get a vauxhall badge (writing) as my car was de badged before I got it, I have the crest and 'omega3.0v6'. Thanks in advance.
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
Re: Vauxhall badge (writing)
« Reply #1 on: 14 July 2016, 19:09:11 »
As far as I'm aware they're individual letters as opposed to a "solid" badge aren't they?If you bought a "badge" from Vx then the likelihood is that they'd come on a strip of backing paper so that you'd stick them on all in one go.No idea of prices I'm afraid.Failing that take a slim bladed implement to a breakers yard and peel them off a Vauxhall [are they all the same size?]clean them up and stick them to your car.
Diamond Black Geezer
    • & a silly coupe coming...
« Reply #2 on: 15 July 2016, 11:43:55 »
PFL common to various 90s Vxs... FL, strangely, unique to the Omega.
However, I'd spot the difference, but many people would probably not give it a second look. Especially as many makes practice using a different font for the model name to the manufacturer.
Get someone to measure the distance between the V and L, (and the distance from the bottom of the bootlid) then acquire some off a breaker, cut your own sticky foam (couple of quid on ebay for a roll of 3M stuff) make a template. (otherwise known as any old shatterproof rule sellotaped to the bootlid) and you're done  :)
In my days owning a FL I did consider replacing the Omega's script with the later style (which is still used I think) acquiring the letters for 'OMEGA' would require a FL Signum or Insignia badge, the only models to use a 'G' other letters from Corsa Vectra Astra easier to source etc.
« Last Edit: 15 July 2016, 11:48:46 by Diamond Black Geezer »
« Reply #3 on: 16 July 2016, 00:38:31 »
Welcome to OOF  :y
flyer 0712
« Reply #4 on: 16 July 2016, 11:07:13 »
Hi and welcome to oof, :y
Varche
  • middle of Andalucia
    • Golf Estate
« Reply #5 on: 16 July 2016, 16:19:59 »
Hola! Welcome to the forum.  :y
If you get stuck , I have some here in Spain. Off a mini face lift Omega. Also have Irmscher letters too.
migiestate
  • Liverpool
    • 03 Omega 2.2 Estate
« Reply #6 on: 16 July 2016, 22:52:28 »
Hello and welcome to the forum. :y
« Reply #7 on: 17 July 2016, 02:29:10 »
Hi, welcome to the forum.  :y
Omegadone
    • 2 mv6s
« Reply #8 on: 18 July 2016, 17:29:08 »
Thanks everyone for the fast help and the welcomes, got one at a breakers so I was lucky enough, now to get mv6 no2 looking well beside my blue one! Thanks.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #9 on: 18 July 2016, 17:32:00 »
Bit late, but I think I may have a complete Vauxhall' badge (new).
Hoof'land storeman.
