Author Topic: (Technically) an Omega question....  (Read 3449 times)
Diamond Black Geezer
    • & a silly coupe coming...
« on: 20 July 2016, 14:40:10 »
Anyone know if leads that fit a 3.0 24valver (Opel Omega, you see) will also fit a 2.8 carb Royale engine? I'd guess at 'yes', as they're essentially the same engine. But just wondered...  ta  :y
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: (Technically) an Omega question....
« Reply #1 on: 20 July 2016, 14:46:57 »
Royal was a straight 6 wasn't it?
But if you mean HT leads, things to consider are lead length, probably no diss pack, guessing Distributor? so possibly resistive leads, or built in ballast?
« Reply #2 on: 20 July 2016, 14:54:29 »
Aye, HTs, and yes, the straight 6, which was (basically, if not actually) the same engine/block from the 60s 2.8s, to the final Lotus and 3.0 / 4.0 irmsmcher engines. (yes I know there's a million differences, but we're talking broadly)
A 6cyl project may be occurring in the near future and I'm just sounding out what parts are available...
« Reply #3 on: 20 July 2016, 14:57:47 »
Don't see why not, the distributor and plugs were all in similar places
« Reply #4 on: 20 July 2016, 14:58:42 »
I know Keith ABS will most likely know for sure, and he also sells a range of them, but that's one Mark vote, in the right direction, anyway.  :y
« Reply #5 on: 20 July 2016, 15:00:27 »
But then if it was me, the first thing that would get upgraded is the ignition setup ! (on any prehistoric car I bought)
« Reply #6 on: 20 July 2016, 15:02:02 »
That is a thought.. hmmm.. can of worms I appear to be opening here  :)
« Reply #7 on: 20 July 2016, 15:04:36 »
Its by far the weakest thing on any older engine, have Megajolted a few cars from Rover V8 through to Type 1 air cooled, every one showed a night and day improvement (the air cooled yielded better starting, ran significantly cooler, throttle response much improved and far more economical)
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #8 on: 20 July 2016, 15:28:08 »
Yes, the fuel savings on a V8 with Megajolt will soon pay for the installation, especially if the distributor needs replacing. The better hot starting is a real boon, and the ability to time ignition correctly allows real optimisation of multi-carburetor installations. The bigger and lazier the engine the better the results seem to be.
« Reply #9 on: 20 July 2016, 15:31:29 »
I used to think the same until we did the Beetle engine.....which had been fully rebuilt with new standard dizzy, coil etc.......and it transformed that asthmatic little lump to! :y
« Reply #10 on: 20 July 2016, 15:32:57 »
Just looked them up, fair few quid, but everything's relative, I suppose, and that includes the lot, inc leads, loom etc. If it's tweaked from 20mpg to 30mpg, that will pay for itself relatively soon. Hmmm... more food for thought...
  • Chatham, Kent
« Reply #11 on: 20 July 2016, 15:36:20 »
Beetle engines are like the A-series: they're so badly designed that even a small change usually makes a worthwhile improvement.
  • Chatham, Kent
« Reply #12 on: 20 July 2016, 15:46:49 »
The 'hard' part is fitting a trigger wheel to the crank pulley, but really it's a simple lathe job. Then you'll need an Edis 6 ECU, crank sensor, wiring and coil pack, which come up on Ebay, or you might be able to find a V6 Mondeo or Jag to rob it from.
With a little scrounging you'll do it for less than £250, much less if you're lucky.
I might still have a Megajolt ECU and loom somewhere that would be cheap.
« Reply #13 on: 20 July 2016, 15:48:55 »
Very much watch this space, then boys. Will let you know what pans out. As ever, thanks Nick and Mark.  :)
