Author Topic: steering wheel puller  (Read 6871 times)
blue_dream
  • Wellingborough
« on: 23 July 2016, 21:33:24 »
Evening guys
 Has anyone in the Northampton area got a steering puller for the omega, decided to change the heater matrix the hard way and im stuck with getting the steering wheel off.  :-\ :-\
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: steering wheel puller
« Reply #1 on: 23 July 2016, 21:45:26 »
There's no such thing.
Loosen, but don't remove the nut.
Wind the seat back as far as it will go.
Grasp the wheel with your hands 180degrees apart and jerk the wheel as hard as you can. This might take several goes, as the wheel probably hasn't been off before. It's on a splined taper, and it's the jerk that releases the taper.
You could remove the nut, but will smack yourself in the face with the wheel when it does release.
« Reply #3 on: 23 July 2016, 21:51:26 »
They don't always come off using that technique
  • Chatham, Kent
« Reply #4 on: 23 July 2016, 21:55:33 »
  • Chatham, Kent
« Reply #5 on: 23 July 2016, 21:56:08 »
never failed me yet. It can be quite hard work though ;D
« Reply #6 on: 23 July 2016, 21:58:07 »
You learn something every day. Looks really wimpy; those lugs don't look up to much.
I made mine for my Manta, I bent the wheel slightly trying your method, but it worked on my Omega too.  :y
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #7 on: 23 July 2016, 22:43:28 »
There's no such thing. .....
Course there is ...... http://www.ebay.co.uk/itm/LASER-TOOLS-2370-STEERING-WHEEL-PULLER-GM-/311459021474?hash=item48846782a2:g:u24AAOSwU~FWEl84
I've got one of those, works a treat. Before that I had many a battle, rocking and heaving the wretched thing. £18 well spent.
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #8 on: 23 July 2016, 23:12:28 »
I normally do Nicks method, last time I ended up with a black eye and a nose bleed.  :(
  • Chatham, Kent
« Reply #9 on: 24 July 2016, 00:32:13 »
Which is why you always leave the nut on a couple of turns. Unless you're watching somebody else do it, and need a laugh.
« Reply #10 on: 24 July 2016, 00:37:44 »
Never had to use a puller, also used Nicks way on numerous cars over the years.  As said never fully remove centre nut until wheel is off the splines  ;)
terry paget
    • 3 Astras 2 Vectra
« Reply #11 on: 24 July 2016, 08:02:49 »
Nick's way is Haynes way. I have done it enough times on Senators, but when it came off I felt entitled to a round of applause and a cup of coffee. A bit like removing suspension joints with two hammers. Using the right puller makes it a lot easier, and one of the joys in my life is buying the right tools to make jobs easy.
McBandy
  • Havant
    • GLS 2.5 manual
« Reply #12 on: 24 July 2016, 09:48:49 »
Lol at some of the replies, yeah Nicks method works for me  :y
Mr Gav
  • Leeds
    • Nissan 370z GT Edition
« Reply #13 on: 24 July 2016, 12:20:55 »
They`re quite robust, I got one after my last battle with a Senator steering wheel, it just wouldn`t budge.
blue_dream
  • Wellingborough
« Reply #14 on: 25 July 2016, 08:56:40 »
Hi guys
Thanks for your replys, Looks like i'm on ebay tonight, thanks for the heads up on the lasor tool  :y :y
