Author Topic: Cabin recirculation  (Read 3841 times)
Stu.C
  • Lancashire
    • 2.0 Capri / 3.0 Elite-ish
    • Visit the blog...
Cabin recirculation
« on: 25 July 2016, 15:47:47 »
Okay, so the only thing(*) that's bugging the hell out of me on the "new" '98 Elite is the fact that every time I turn the ignition, the cabin air recirculation is switched on even though I switched it off last time. Is there some magic combination of button pressing I have to do to make it stay off ??
(*) Okay, there's actually a small list, but we'll start with this one ;)
Nothing better to do ? Visit the blog at cuyahoga.co.uk
Re: Cabin recirculation
« Reply #1 on: 25 July 2016, 17:46:04 »
Try a reset of Auto and Off for 5 secs
Magwheels
    • 2.2 dti Elite saloon
« Reply #2 on: 25 July 2016, 18:36:33 »
Could be a knackered air quality sensor.
« Reply #3 on: 25 July 2016, 19:03:06 »
Pretty unlikely on a PFL/MFL Elite....   ....as it doesn't have one :P
  • Auckland
    • Mazda MPV
« Reply #4 on: 25 July 2016, 23:04:21 »
When this question came up a few years ago I think MDTM pointed to a technical bulletin from Vauxhall saying it could be caused by the battery voltage dropping below 8 volts (from memory).
Mine used to do it but hasn't done so since I had to replace the regulator in the alternator so they may be on to something....
Stu.C
  • Lancashire
    • Visit the blog...
« Reply #5 on: 26 July 2016, 11:15:18 »
Excellent, I'll give that a go at lunchtime. Failing that, I'll pop down to Tesco for a sacrificial chicken...
106pete
  • Plymouth
    • Omega 3.0 elite
« Reply #6 on: 26 July 2016, 11:44:05 »
If you charge the battery then start the car, it may prove a voltage issue. When my alt packed up I didn't notice the ac turning on by itself tho.
Magwheels
« Reply #7 on: 26 July 2016, 19:06:25 »
Are yes, Should have read the post more thoroughly. 98 being the clue!!
Stu.C
  • Lancashire
    • Visit the blog...
« Reply #8 on: 26 July 2016, 20:23:38 »
No chicken needed - the time honoured method of turning it off and back on again did the trick  :y
Now for the next item on the list...
