Author Topic: Cleaning small breather on 2.2  (Read 2393 times)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« on: 26 July 2016, 08:10:51 »
If breathers are blocked cam cover gaskets blow. I am struggling to clear the small breather on my recently purchased petrol 2.2. It looks like it should be simpler than on the 2.0 'cos there is no coolant ring around it. However I could not get a wire through it, nor even see a hole on the inside. So I removed the throttle assembly from the old 2.2 awaiting the scrapper, and dsicovered there is a hole on the inside.
Must persevere. Also I cannot see how to unplug the cable to the throttle motor. It looks as if I should press down on the grey centre bit, then pull. Should I pull harder?
terry paget
    • 3 Astras 2 Vectra
Re: Cleaning small breather on 2.2
« Reply #1 on: 26 July 2016, 10:50:08 »
Solved it. In case anyone else has this problem, following pics will explain all.
terry paget
    • 3 Astras 2 Vectra
« Reply #2 on: 26 July 2016, 16:27:10 »
Removed throttle box, found small idler hole completely blocked.
Cleaned throttle box, pusged wire through smal;l idler hole.
Investigating whether cam cover gasket was gone, I removed the plug stick. Therews a trace of oil on sticks 3 & 4, so I cleaned up the sticks and changed all the plugs for the Vx000 plugs in the 2.2 awaiting collection by scrappie. He will pay me £35 for the wreck, last year he paid £30 so things are looking up.
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #3 on: 28 July 2016, 21:45:03 »
Scuttle wants sealing on that car  :y
Edit   Cancel that Wrong end  :-[
« Last Edit: 28 July 2016, 21:48:25 by BIGtime »
terry paget
    • 3 Astras 2 Vectra
« Reply #4 on: 28 July 2016, 22:16:53 »
That yellow deposit on sticks 1 & 2 puzzles me too.
steve6367
« Reply #5 on: 28 July 2016, 23:00:26 »
Me three, it's what they normally look like with water in the plug wells...
flyer 0712
« Reply #6 on: 28 July 2016, 23:03:09 »
When i cleaned mine out,someone had already had a go at sometime and broken that clip..shame they didnt know your screwdriver trick. :y
« Reply #7 on: 29 July 2016, 16:21:56 »
Can still be scuttle, car may have been parked nose down in which case the water tends to pool at the no1 plug end
frostbite
  • Roanapur City aka Skem
    • 00' e46 325i se
« Reply #8 on: 29 July 2016, 18:36:35 »
Could it have been grease. I remember it being on my dad 04 astra
e46 325i se - 1.8vvti avensis liftback
