Author Topic: Aerial  (Read 2285 times)
Discoja
  • Peterborough
    • Omega 2.2 dti cdx
Aerial
« on: 01 August 2016, 10:28:42 »
Hi again all.
Before ripping the old aerial off the roof and replacing with a shark fin  (due to spoiler fitting), are there any other suggestions? Also, does anybody know if I would I need a powered aerial or normal aerial for a 2003 CDX Estate with a Philips CCE 2006.
Many thanks
Of all the things I've ever lost, my mind I miss the most.
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Aerial
« Reply #1 on: 01 August 2016, 11:16:24 »
Hi again all.
Many thanks
Fitting a Sharks Fin is only going to make your radio reception worse over the standard VX Estate set up, the VX whip and Amp does a good job.
Personally I would leave it be, if your fitting a Prodrive rear door spoiler, yes they do touch the aerial when fully opened, but its no big deal, your car will probably fail its MOT or become a Classic Car before any damage is done to the either the Aerial Whip or Spoiler paint work.
Alternatively, long term you could source a Prodrive aerial ball adaptor that fits between the aerial base and whip and points the aerial more vertical so it misses the spoiler
iansoutham
  • SE London
    • Omega 2.0 m/f/l est CDX
Re: Aerial
« Reply #2 on: 01 August 2016, 14:46:35 »
Or just the more upright one from another Vauxhall. I have the spoiler and my aerial base is from a Vectra B estate (same as Astra G van). Works fine for me. Just make sure your connections are right before starting.
