Author Topic: Heated seats  (Read 3936 times)
atann
  • Canterbury
    • Vauxhall Omega 2.6 CDX
Heated seats
« on: 12 August 2016, 00:34:43 »
I know it's not that time of year, but though I'd see if the front seats worked. Put them on 6 for five minutes , nothing. I've read that setting 3 or 2 should be used. How long do they normally take to heat up, if working properly?
Re: Heated seats
« Reply #1 on: 12 August 2016, 00:57:40 »
Usually noticeable in a minute or two... :y
That said, did the switches light up? If yes, what was the outside temperature? As you'll struggle to feel the difference at much over 15° imho... :-\
Omega VT3000
  • Essex
Re: Heated seats
« Reply #2 on: 12 August 2016, 10:34:19 »
Broken contacts/wiring in the seat itself is common.
Disconnect the connector and use a multimeter to check the resistance between the two contacts may help?
atann
  • Canterbury
Re: Heated seats
« Reply #3 on: 12 August 2016, 23:42:12 »
Yes the switches did light up. Outside temp 21c, might explain why! I'll try again when cold. Cheers.
Terbs
  • Brackley/Wareham
  • The Freezer Geezer
    • CD Saloon 2003
Re: Heated seats
« Reply #4 on: 14 August 2016, 12:04:56 »
When my heaters are on, you can't mistake a hot backside, whatever the outside temperature ???
Re: Heated seats
« Reply #5 on: 14 August 2016, 13:11:12 »
Exactly this... I use mine all year round because of my back :y
dave-b
  • Wigan, Lancs.
    • Elite 3.0 F/L
Re: Heated seats
« Reply #6 on: 14 August 2016, 20:53:15 »
The switches on my f/l elite light up, but no heat in the seats. I assume the element in the seats have failed but its strange that neither front seat works as the cars not had a hard life. Is there anything else to check before I take the seats out?
Terbs
  • Brackley/Wareham
    • CD Saloon 2003
Re: Heated seats
« Reply #7 on: 16 August 2016, 00:01:05 »
You and me both, Paul. :y
Indeed, all my Omega's have heated seats, and to be honest, whether leather or cloth, if they are only set to 2 or 3, you can tell within minutes they are working. Outside temperature imo is irrelevant, at least in my cars. Just ask my back and backside !!! ;)
Terbs
  • Brackley/Wareham
    • CD Saloon 2003
Re: Heated seats
« Reply #8 on: 16 August 2016, 00:05:01 »
No expert in this, but strange that both seats failed together. I would think there is a common problem between the two, rather than both seat elements packing up at the same time. Big coincidence.!! Just an opinion :y
