AR25 vs AR35
Started by Shackeng, 13 August 2016, 09:26:37
Shackeng
There seem to be plenty of AR25's available, and I am wondering what the physical differences are. I guess that it is only a difference in the clutch and drive plates, which should be fairly easy to swap. Has anyone any experience of doing this? :-\
biggriffin
You certainly like a challenge  :)
Hoof'land storeman.
Shackeng
Quote from: biggriffin on 13 August 2016, 09:44:08
It's what keeps me going. ::)
frostbite
e46 325i se - 1.8vvti avensis liftback
zirk
Depends what you plan to do with the box afterwards, bearing in mind high Torque Engine will eat a low Torque Autobox for breakfast.
AR25 is rated at 250Nm, AR35 is 350Nm.
Shackeng
Quote from: zirk on 13 August 2016, 17:55:19
Yes but the case is the same, so no reason why the relevant AR35 bits should not be fitted - I think :-\ Hence my OP. If it turns out that there are differences in the rest of the unit, then it wouldn't be worth considering, but as I said, if just clutches and WHY, it may be worth it. :-\ :y
frostbite
You may also find the torque convertor is whats the limiting factor. Very easy to burn out
Shackeng
Well I'm still using the original that was on the AR25. :y
It's the clutch packs that are different. The torque converter is just a hydraulic coupling so pretty difficult to break. You also need to keep the torque converter from the original engine as they are specified to suit the characteristics of the engine.
I'm sure you could swap the clutches over. I think the ar35 just has a couple of extra plates in each. What else is different is anyones guess. Spacers perhaps. If you've ever stripped an automatic box to that level you'll know that just remembering how it goes back together is a formidable challenge.
frostbite
It may be a hydraulic coupling but it has 3 parts that turn in oposite directions, if the turbine or stator stop flowing the fluid the box is guaranteed to break
Shackeng
#10
Quote from: Kevin Wood on 16 August 2016, 09:59:29
Interesting, as the one I have just replaced the thrust washer on, supposedly an AR25 rebuilt as an AR35, has only two clutch plates, the same as in my old AR25. Was I sold an AR25 under a false pretence? I could take the pack out of the Senny box and put it in mine if it has more plates. I was waiting to fix the rest of it before removing the bell housing. :y
Shackeng
If that refers to the clutch pack in the housing behind the pump, I guess I am now qualified. ::)
I believe the clutch directly behind the pump is for the torque converter lockup, which only operates under relatively light load anyway, so it may well be that it isn't different on the AR35.
Shackeng
Quote from: Kevin Wood on 16 August 2016, 23:01:56
Ah, that explains it, thanks Kevin. So I still don't know for certain whether the repaired box is an AR35. However, I will comtinue to assume it is, and put it back on so that I can drive it for sump replacement. :y :y :y
