Author Topic: ignition switch  (Read 3484 times)
blue_dream
  • Wellingborough
ignition switch
« on: 14 August 2016, 13:22:11 »
Afternoon guys
   Im after some advice, after putting back the dash after replacing the heater matrix my mig will not start, it will turn over
no problem, i'm wondering do i need to have the ignition key trans sponder reprogrammed, i had taken off to get the dash out of the way.
 and has been off for a few days, disconnected the fuel line in and turned over but no fuel out, so just wondering if its on immliser state.  :-\ :-\
blue_dream
  • Wellingborough
Re: ignition switch
« Reply #1 on: 16 August 2016, 16:37:59 »
Hi
Can anybody help
Matchless
  • Nottingham
    • A white van
Re: ignition switch
« Reply #2 on: 16 August 2016, 20:04:30 »
No reprogramming needed.
If it is an immobiliser issue then the EML will be flashing whilst the engine is cranking.
This is likely to be a missed connector or a poor connection somewhere - you will have disturbed a lot of wiring if you took the complete dash out.
Have a good look at the connectors, one of the pins may have been pushed back within the outer shell.
omegod
  • liverpool
    • 2017 Seat Ateca
Re: ignition switch
« Reply #3 on: 16 August 2016, 20:20:05 »
Is the little chip still in the keyfob? worth a look,been there and done it  ::)
As above EML would be flashing
blue_dream
  • Wellingborough
Re: ignition switch
« Reply #4 on: 17 August 2016, 21:18:21 »
hi guys
 Thanks for your replys, no eml, but i have no fuel coming through the main feed pipe very unual, engine will crank
  but not fire, done nothing in the engine, checked all fuses and relays everthing is fine, the key switch had to be taken off and had been for a number of days,just wonder if this would have an effect, i'll keep looking, thanks again guys. :y :y
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: ignition switch
« Reply #5 on: 17 August 2016, 21:28:56 »
hi guys
Then you've managed to disconnect or damage the immobiliser sensor/wiring around the ignition switch. Immobiliser works on the fuel pump; it will crank over until you flatten the battery or cook the starter motor.
blue_dream
  • Wellingborough
Re: ignition switch
« Reply #6 on: 23 August 2016, 15:58:19 »
Hi Nick
Thanks for your info, this is what i thought, ignition switch fell apart, i'll replace this first which is cheap but i still think its to do with the imbo to the key, this is the only area that has given me problems, everything else fine.
