Author Topic: Wanted: V6 Injector Loom  (Read 10109 times)
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
Re: Wanted: V6 Injector Loom
« Reply #15 on: 22 August 2016, 04:59:02 »
I believe I have one of the injector looms from under the plenum. Will have to double check. Free to good home.
I have, found it in the parts shed the other day but he said it had two grey plugs ? think I have a 3.2 engine loom too :y
« Reply #16 on: 25 August 2016, 13:14:42 »
The engine loom under the plenum (with the 6 injector plugs) is easily sourced. As Gollum says, the other half generally gets scrapped with the car ::)
joff
  • swindon, wilts
  • Discovery TD5 ES
« Reply #17 on: 25 August 2016, 13:29:05 »
The other part being the engine loom ?
« Reply #18 on: 25 August 2016, 17:47:35 »
The other part being attached to he car that the engine loom plugs into ;) :y
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #19 on: 25 August 2016, 18:38:09 »
I'll have a 2.6 breaker here in the next week hopefully if your not sorted
« Reply #20 on: 25 August 2016, 22:44:00 »
Before it goes to the scrapyard can you cut the plug and a length of loom off of the car and hold in stock please? It's something that will likely get requested again for LPG conversions :y
joff
  • swindon, wilts
  • Discovery TD5 ES
« Reply #21 on: 27 August 2016, 09:10:28 »
I have the full loom from injectors and the full engine loom with grey plug that fits onto the injector loom and is still part of the engine loom, taken from a 3.2 :y off the car ready for posting if needed
« Reply #22 on: 27 August 2016, 13:35:49 »
Thanks for all the responses, but I no longer require this now.
joff
  • swindon, wilts
  • Discovery TD5 ES
« Reply #23 on: 27 August 2016, 13:55:24 »
