Author Topic: AR25 Sump Gasket Change  (Read 1844 times)
Scatmancraig
  • Skellingthorpe, Lincolnshire
« on: 17 August 2016, 09:45:31 »
I am on the verge of doing the sump gaskets, filter and fluid change on the AR25 in my car.  Got the gaskets and filter, plus 6 litres of Dexron III ATF ready.
Is 6 litres of ATF going to be enough?  I'm going to be replacing the radiator at the same time, so that will take car of any ATF remaining in there.  I realise that there will be some old ATF remaining in the torque convertor, so wasn't sure if I needed any more at this stage.
When changing the sump gaskets, do I use any additional sealant with them or just the gaskets on their own?  I've never had the sumps off an AR25 before.  I had read somewhere that a smear of vaseline on the gaskets does the trick, anyone used that before?
Re: AR25 Sump Gasket Change
« Reply #1 on: 17 August 2016, 10:43:45 »
I'd say 6 litres is marginal. Best to have 8 litres or so to hand to top up after a a partial change.
I would probably only smear the gaskets with ATF on refitting. Any other kind of mineral grease might contaminate the friction surfaces in the gearbox resulting in it failing.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #2 on: 17 August 2016, 11:29:37 »
Isn't there a how to in the helpful maintenance section ;).
Both sumps off, and blow thro the cooler pipes, takes about 8ltrs, so best buy 10, then you can also change the power steering fluid too. :Y, that takes about a 1ltr.
Hoof'land storeman.
Mr Gav
  • Leeds
    • Nissan 370z GT Edition
« Reply #3 on: 17 August 2016, 13:43:15 »
Hi Craig,
These are the capacities taken from the Carlton manual and I would expect them to be similar on the Omega as it`s basically the same box.
Capacities are drain and refill   2.6 litres
After removing the large sump  4.7 litres
From dry                               6.4 litres
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
« Reply #4 on: 17 August 2016, 19:46:50 »
According to Haynes capacities are;From dry 8.4litres,After removing main sump 4.4litres,both these figures are noted as "approximate".
