tablets
Started by tigers_gonads, 20 August 2016, 10:24:26
zirk
#15
Quote from: migmog on 21 August 2016, 23:45:24
that is cheap esp with 32GB storage :o
anyway don't forget with a micro sd card slot you can add storage - usually they say 32gb max but a 128gb sd card works just fine in my kocaso tablets.
Theres a big difference between on board SSD Storage and SD Expansion Storage.  ;)
Where its quoted as 32gb SD storage max, thats due to the device working with Fat32 Format, above that devices are working eFat upwards.
omega2018
Quote from: zirk on 22 August 2016, 01:02:16
access time is not too dissimilar: 0.5ms v 0.35ms :y
Quote from: migmog on 22 August 2016, 10:53:34
In reality, an SD is a huge magnitude lower in performance, and the ones at sensible prices more prone to corruption, than the built in NAND.
There is a reason why every single manufacturer doesn't use SD for anything other than secondary, temporary storage ;)
omega2018
usual forum response to people's actual experience - i agree with the secondary storage bit but rest is rubbish.  what is "a huge magnitude" lower?  yes performance is lower but nowhere near 1 order of magnitude let along a huge magnitude.  look up "magnitude".
"temporary" is dangle berries too, yes back up any data you store on sd (or ssd or hd for that matter) but why would you only use it for temporary storage.  never lost any sd data yet touch wood. many phones use sd storage as their main storage.
