Author Topic: Y32SE rear exhaust box hangers  (Read 2661 times)
tport
  • east mids
« on: 22 August 2016, 18:03:29 »
MOT passed today - hurray.  Two advisories - boo.  First involves a wire brush and some underseal on the chassis next to the steering idler - £0.  The other is to replace all thre hangers on the rear box as only one is in place and this is already badly split.  Question is, where to buy?  Any ideas?  Thanks
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: Y32SE rear exhaust box hangers
« Reply #1 on: 22 August 2016, 19:32:26 »
From Ebay. Or put wanted advert in test section, and then nice admin will move it. :)
Hoof'land storeman.
frostbite
  • Roanapur City aka Skem
    • 00' e46 325i se
« Reply #2 on: 22 August 2016, 19:49:29 »
Ecp have some fiesta ones that are thicker and stronger than vaux ones for 83p
e46 325i se - 1.8vvti avensis liftback
neil74
  • newport
    • 2.6 elite estate.
« Reply #3 on: 22 August 2016, 21:45:06 »
As my car is up for it's MOT i thought i'd check around the car for anything obviously missing or damaged. and much to my surprise neither of the rear rubber hangers were there. so off to Halfords and i bought two that were apparently for a ford escort and they fit a treat.
frostbite
    • 00' e46 325i se
« Reply #4 on: 23 August 2016, 07:44:10 »
You will also need to replace the spring clips to stop the rubbers working loose again
biggriffin
« Reply #5 on: 23 August 2016, 08:25:53 »
Lockwire in a figure of 8, does
Hoof'land storeman.
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #6 on: 23 August 2016, 10:17:25 »
Clips from main dealer 94p   plus vat. or small jubilee clips
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #7 on: 23 August 2016, 10:49:55 »
Use a repair washer if going with jubilee clips.
Without extra retention my backbox hangers only stay in place for a few weeks. I made a couple of 25mm collars with a retaining screw because I was fedup with repeatedly fitting new hangers. Those bad tempered 5minutes on a Sunday evening have proved to be a permanent solution.
