Pages: 1 [2] 3  All   Go Down
Author Topic: This DPF thingy....  (Read 12256 times)
citroenguy
  • Sweden
    • 2005 Citroën C5 2.0SX
Re: This DPF thingy....
« Reply #15 on: 23 August 2016, 14:12:27 »
The DPF in my dads C5 lasted about 125 000 miles, mostly motorway driving though. Was about 500£ to replace at a dealer. PSA uses an additive called Eolys to make dpf regen possible at a lower temperature. Therefore it can more easily regenerate.
124k on the C5
I like Omegas Senators and all other big 90´s euro saloons.
Previous motors: 3x Rover 600s, Citroën ZX, Volvo 850
« Reply #16 on: 23 August 2016, 16:09:06 »
You should actually never have to replace a DPF as the ash build up with high mileage is easily removed (plenty of companies offering this service and can be done to a lesser extent with a large compressor and blowing it through the wrong way......lots comes out!).
Some manufacturers use an additive (which of course needs topping up) which lowers the DPF regen temperature by circa 50 deg C and a smaller DPF (tends to limit the time between regens to circa 500 miles) is also used which heats up a bit faster. This all helps but if you do loads of town driving it will still catch you out unless you can react to a regen and get on a good drive.
« Reply #17 on: 23 August 2016, 16:14:16 »
These Renaults/Nissans don't appear to show any signs of attempting a regen. Just can't figure it out. Wifey has done nearly 6000 miles in hers and no sign of any lights, no funny smells, no increased mpg, no increased fan speed.......nowt.
« Reply #18 on: 23 August 2016, 16:21:24 »
It will have done many in that time, she must do a few clear runs?
« Reply #19 on: 23 August 2016, 16:32:29 »
A roads for, maybe, a clear five mile run.
« Reply #20 on: 23 August 2016, 17:35:21 »
Nah.....that's what she tells you.
In reality she drives all the way down to London to see her fancy man.
Foot to the boards all the way. :)
« Last Edit: 23 August 2016, 17:40:24 by Doctor Opti »
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #21 on: 23 August 2016, 17:58:24 »
Manufacturers found that when a regen light illuminated many drivers would stop the car, thinking there was a fault. Which doesn't help the process. They've reduced any noticeable symptoms as far possible for the same reasons. And I know it says in the manual what is happening, why, and what to do, but very few people actually read the things.
Putting a soot filter in the exhaust, and expecting to burn it clean using the same process that created the soot in the first place is an idea that has kneejerk and 'fixing' a symptom rather than the problem written all over it.
X30XE
  • UK
    • 740i,728i,S320 & Disco
« Reply #22 on: 23 August 2016, 18:26:51 »
Good point.  They need to invent one that compresses it into bales like that air ram vacuum. Then when it's full you can just lob it into a hedge and carry on.
Omegatitis : [in remission]
« Reply #23 on: 23 August 2016, 18:49:59 »
Setting fire to your waste products and then releasing the fumes into the atmosphere can't be all that green, surely?  ;D
McBandy
  • Havant
    • GLS 2.5 manual
« Reply #24 on: 23 August 2016, 19:29:57 »
I know Peugeot use adblue (is it called that? ???) That's what our buses use, if anyone doesn't know it's just pig piss! Don't know about Renault but about the time I left Fiat their latest derv POS engine (multijet 2 iirc) didn't need a regeneration cycle as it injected fuel 8 times a second (I remember seeing a very fancy graph)! Very clever people that lot, if you want innovation look at Fiat (sorry for all the brackets)(ps I hated Fiat before working for them, same as Vauxhall!).
« Reply #25 on: 24 August 2016, 08:47:40 »
Totally different, Adblue is for NOx reduction (its Urea) and has no impact on particulate levels, its used by all manufacturers with cars/engines above a certain size (smaller units can get away with a fancy catalyst)  :y. All these bluemotion and bluetec cars basically have Adblue injection
And its 8 injections per cycle, this has no impact on regeneration and they still do regenerate, what it does do is reduce noise and improve power delivery  :y
Oh yes, the Fiat and Gm 1.3/1.9/2.0 engines are the same power plant
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #26 on: 25 August 2016, 07:42:54 »
In 40k plus, I've never experienced a regen. on my Insignia.
I like red cars
TD
  • Swindon
    • Nowt!
« Reply #27 on: 25 August 2016, 18:38:23 »
It must have done loads of them in 40k miles, if it hasn't the your living on borrowed time for the EML to come on and the vx dealer telling you it needs a new DPF  ::)
But its the same in my Mondeo.....ive never noticed it doing one...
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #28 on: 26 August 2016, 07:48:24 »
How do you detect if it's doing a regen?
I like red cars
citroenguy
  • Sweden
« Reply #29 on: 26 August 2016, 07:55:15 »
The "live" fuel consumption goes up.
124k on the C5
Pages: 1 [2] 3  All   Go Up
