Author Topic: oil low warning  (Read 1574 times)
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
oil low warning
« on: 23 August 2016, 20:04:07 »
I had the sump & oil pan off recently & since putting it back together a low warning has appeared. the electric is attached ok. I hope it not the sensor that is inside the oil-pan. it is not low either.
Re: oil low warning
« Reply #1 on: 23 August 2016, 23:52:30 »
Is it near halfway between min and max - that'll bring it on on a cruise.
Failing that, check the sensor is plugged in.
