Author Topic: Indicator/ Brakelight Malfunction  (Read 2784 times)
Figureman52
  • Nottingham
    • 2.6 CD Saloon
« on: 30 August 2016, 13:42:40 »
N/S indicator working fine until I put my foot on the brake. then the indicator slows down and I get a brake light warning on the display.
Is this likely to be a wiring fault, or could it be a fault in the tail light unit itself?
Thanks.
McBandy
  • Havant
    • GLS 2.5 manual
Re: Indicator/ Brakelight Malfunction
« Reply #1 on: 30 August 2016, 17:01:33 »
I think the term is interference which is probably caused by a bad earth, hopefully easy enough to sort
« Reply #2 on: 30 August 2016, 22:34:30 »
Earth fault :y
« Reply #3 on: 31 August 2016, 08:20:36 »
Earth fault :y
Like the Transit I saw yesterday - every time he indicated both reversing lamps flashed in time  ;D
Diamond Black Geezer
    • & a silly coupe coming...
« Reply #4 on: 31 August 2016, 09:22:09 »
In a dusty corner of my mind I have a feeling that Pissy did a similar thing once, before I'd become registered keeper, and I was giving her the once over -  and it was down to having a facelift bulb (with differently placed pins on the bulb) jammed in. Could the wrong bulb cause such as issue?
« Reply #5 on: 31 August 2016, 09:53:02 »
Only if it causes a short to ground ::)
Corrosion or water ingress, or both (but not necessarily in that order) are the most likely culprits ;)
WD40, emery cloth and A.N.Other light cluster should solve it :y
Figureman52
  • Nottingham
    • 2.6 CD Saloon
« Reply #6 on: 31 August 2016, 10:39:39 »
It was an earth fault, ran new earth wire, all sorted.
Many thanks to all.  :y :y
