Author Topic: A/C Dead.....  (Read 2323 times)
A/C Dead.....
« on: 30 August 2016, 18:56:34 »
.... again!  :(  Sigh!  ::)
Happily, I think I've found the cause and it's because the two pipes going into the compressor have been leaking.  :-\  The compressor itself seems to be OK.  :-\
I'm guessing these pipes are sealed with an O ring?  ???  Is it a compressor out job or can I remove the pipes and renew the O rings?  ???
TIA!  :y
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
Re: A/C Dead.....
« Reply #1 on: 30 August 2016, 19:08:16 »
Very difficult with it in place. With the bagpipes removed, I found it very easy to lift forward with pipes still attached once the mounting bolts were out, which again were fairly easy with under access. Then access for pipe removal is simple. :y
Re: A/C Dead.....
« Reply #2 on: 31 August 2016, 13:16:23 »
Thanks Shack!  :y
Am I right in thinking that the A/C pipes are sealed into the compressor with O rings?  :-\
Shackeng
  • Ramsbury
Re: A/C Dead.....
« Reply #3 on: 31 August 2016, 15:24:21 »
Not 'o' rings exactly, but a washer with a rubber seal built into it. Someone will give you the name in a minute. :y
Re: A/C Dead.....
« Reply #4 on: 31 August 2016, 16:40:50 »
Dowty ::)
Re: A/C Dead.....
« Reply #5 on: 31 August 2016, 17:34:28 »
I bought an O ring kit with the condenser so maybe I have what I need as there were several bit and pieces left over....  :-\
Shackeng
  • Ramsbury
Re: A/C Dead.....
« Reply #6 on: 31 August 2016, 17:35:30 »
DrAndyB
  • The Wirral / Cheshire
    • 2.5 V6 CDX Manual (MFL)
Re: A/C Dead.....
« Reply #7 on: 31 August 2016, 19:24:10 »
Dowty ::)
I wouldn't Doubt it  ;D
I seemed to recall similar ones need for the Oil cooler on the V6 ?
