Author Topic: fault code 133 - omega mv6  (Read 3057 times)
thejuzo
  • Finland
    • opel omega mv6
« on: 30 August 2016, 21:04:21 »
Hello, I have strange fault code related to intake manifold valves and I have not figured yet what is causing it..
My car is omega mv6 (x30xe) 1994.
My op com shows this
Error code 133: air intake manifold valve 2 voltage too low
When my car is running it shows air intake manifold valve 2 = active(0v)
And then when engine is off and ignition on active(12v)...
So what to do next?
Re: fault code 133 - omega mv6
« Reply #1 on: 30 August 2016, 21:11:11 »
Did it happen after some work?
thejuzo
  • Finland
    • opel omega mv6
« Reply #2 on: 30 August 2016, 21:14:05 »
Not actually, it just popped up yesterday. My car still works..  but air fuel rate is richer.
« Last Edit: 30 August 2016, 21:15:53 by thejuzo »
« Reply #3 on: 30 August 2016, 21:16:39 »
Shouldn't affect the fuelling.
Can you swap front and back solenoids over, see if fault moves with solenoid or not...
thejuzo
  • Finland
    • opel omega mv6
« Reply #4 on: 30 August 2016, 21:23:23 »
  The fault code still remains after I tried that move method.
 I dont think it is supposed to show active(0v) in op com at idle??
« Reply #5 on: 30 August 2016, 21:36:26 »
The fault code still pointed to Valve 2, even after you swapped the solenoid with the Valve 1 one?
If so, start metering the cable.
Ignore what says op com for now.
thejuzo
  • Finland
    • opel omega mv6
« Reply #6 on: 30 August 2016, 21:47:35 »
Oh sorry. I misunderstand. I'll try that swapping tomorrow.
But how I can test  that this part isnt broken.
Diamond Black Geezer
    • & a silly coupe coming...
« Reply #7 on: 31 August 2016, 13:26:17 »
Does that same part sit on the SAI as well as the intakes? Just in case it does a simple swap round would eliminate it?
thejuzo
  • Finland
    • opel omega mv6
« Reply #8 on: 31 August 2016, 17:05:22 »
I have now swapped valve 2 with valve 1 solenoid and same error still stays and comes back after cleaning errors.. It gives 12v to valve solenoid when ignition or when engine on.  Op com says active(0v) for valve 2 when engine on and because of that, it throws that error 133..
Any ideas?
« Last Edit: 31 August 2016, 17:21:38 by thejuzo »
thejuzo
  • Finland
    • opel omega mv6
« Reply #9 on: 31 August 2016, 17:25:19 »
And I have checked with voltmeter, wiring seems to be ok.  The wiring for valve 2 solenoid will give 12v and engine on, over 13.8v
thejuzo
  • Finland
    • opel omega mv6
« Reply #10 on: 31 August 2016, 18:22:14 »
Which one is valve 2?  front of engine or rear of plenum?
« Reply #11 on: 01 September 2016, 13:38:39 »
Firstly, ignore op com. Its shit.
Did the fault stay with valve 2, or move to valve 1?
If it stayed with valve 2, do a resistance chack of wiring between the valve and the ECU (you will need to remove ECU to test the wiring.
thejuzo
  • Finland
    • opel omega mv6
« Reply #12 on: 03 September 2016, 00:19:05 »
Well I did change solenoid valve 1 to 2.  It still stayed error for valve 2.  I also tested wirings resistance between ecu and valve. Pin 31 and 46. Both checked and seemed to be ok.
Anyway when I switch to ignition, it gives about 6-8v to valve's plug for about one sec with voltmeter, then it goes back to 0v..
Shouldn't it be 12v all the time?
thejuzo
  • Finland
    • opel omega mv6
« Reply #13 on: 04 September 2016, 00:14:02 »
Today I found that pin 31, ground pulse (from ecu) doesnt give any pulses. I tested it with voltmeter, by putting its - to brown/black wire and + to the battery's +.  No voltage changes between 1000rpm to 6k.
Why is not ecu sending ground pulses from pin 31... Is my ecu faulthy?
