Author Topic: Urgent - All users read and test  (Read 10998 times)
Bo Bo
  • Coventry
Re: Urgent - All users read and test
« Reply #30 on: 28 November 2006, 22:13:18 »
PM on way......
Received, and I'm guessing you're at work - that looks like corporate PC to me.  I suspect you're using proxies, so I need a different test for you....
It is & I am  :(
« Reply #31 on: 28 November 2006, 22:14:42 »
OK, if ping test not working, try browsing to this:
http://www.omegaowners.com/dnstest.htm
if you get a message saying DNS Test, thats fine :)
if you get some other error, let me know...
Bo Bo
  • Coventry
« Reply #32 on: 28 November 2006, 22:16:56 »
Got DNS Test, right I've gotta go & do a bit.........
Well actually it's break  ;)
« Last Edit: 28 November 2006, 22:17:33 by paulmccristall »
rogerreno
  • Deepest darkest Coalville
« Reply #33 on: 28 November 2006, 22:26:41 »
PM sent Jaime...we got there in the end  ;D
Elwood: It's a 106 miles to Chicago. We got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
Jake: Hit it!  8-)
« Reply #34 on: 28 November 2006, 22:32:24 »
replied. You should be ok when I change some stuff back tomorrow...
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #35 on: 28 November 2006, 22:40:37 »
No probs.....
I like red cars
Nickbat
« Reply #36 on: 28 November 2006, 23:15:47 »
PM sent  :y
Timbuk
  • Telford
  • owned a Datsun 120y once!
« Reply #37 on: 28 November 2006, 23:30:48 »
No probs :y
Markjay
  • London
« Reply #38 on: 28 November 2006, 23:31:41 »
Response from www.dnsstuff.com for Reverse DNS on www.omegaowners.com:
www.omegaowners.com is not an IP address, so I am using 217.155.56.220 (the A record for www.omegaowners.com).
Preparation:
The  reverse DNS entry for an IP is found by reversing the IP, adding it to "in-addr.arpa", and looking up the PTR record.
So, the reverse DNS entry for 217.155.56.220 is found by looking up the PTR record for
 220.56.155.217.in-addr.arpa.
All DNS requests start by asking the root servers, and they let us know what to do next.
See How Reverse DNS Lookups Work for more information.
How I am searching:
Asking d.root-servers.net for 220.56.155.217.in-addr.arpa PTR record:
       d.root-servers.net says to go to ns-ext.isc.org. (zone: 217.in-addr.arpa.)
Asking ns-ext.isc.org. for 220.56.155.217.in-addr.arpa PTR record:
       ns-ext.isc.org [204.152.184.64] says to go to ns1.zen.co.uk. (zone: 155.217.in-addr.arpa.)
Asking ns1.zen.co.uk. for 220.56.155.217.in-addr.arpa PTR record:  Reports slcs-rh4-2.lettronics.com. [from 212.23.3.1]
Answer:
217.155.56.220 PTR record: slcs-rh4-2.lettronics.com. [TTL 86400s] [A=217.155.56.220]
« Last Edit: 28 November 2006, 23:33:28 by markjay »
Alas, no more Omegas....
The Barge Captain
« Reply #39 on: 28 November 2006, 23:34:44 »
Preparation:
How I am searching:
Answer:
Yer Wat?
Did the ping test - 217 155 56 220 came back ok
« Reply #40 on: 29 November 2006, 09:25:47 »
Preparation:
How I am searching:
Answer:
Yes, thats correct response, but there is a possibility that some caching DNS servers used by ISPs may have cached the wrong settings, hence asking everyone.  Hopefully shouldn't be too much of a problem as we were runnning quite a long TTL, so hopefully most DNS caches didn't even see the HU changes.
My biggest concerns is corporate proxies, as they, for some reason, seem to ignore DNS TTL values...
« Reply #41 on: 29 November 2006, 09:28:32 »
Seeing as we have had 100% success on DNS resolution, I am going to undo some of yesterdays bodges at 10am today...
« Reply #42 on: 29 November 2006, 10:33:29 »
Changes made. You WILL need to log back in again...
nixoro
  • Hitchin, Herts
« Reply #43 on: 29 November 2006, 11:38:19 »
Microsoft Windows 2000 [Version 5.00.2195]
(C) Copyright 1985-2000 Microsoft Corp.
C:\Documents and Settings\nixonr>ping www.omegaowners.com
Pinging www.omegaowners.com [217.155.56.220] with 32 bytes of data:
Reply from 81.144.126.129: Destination host unreachable.
Ping statistics for 217.155.56.220:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 0ms, Maximum =  0ms, Average =  0ms
Not looking good.
From work internet so may have problems.
DNS Test worked for me.
« Last Edit: 29 November 2006, 11:42:57 by nixoro »
« Reply #44 on: 29 November 2006, 12:53:29 »
Not looking good.
Are you able to view this site Ok from work though?
Pages: 1 2 [3] 4  All   Go Up
