2001 2.6 CDX Engine ECU
Started by BIZYWZD, 02 September 2016, 13:26:26
BIZYWZD
its there a photo of where the ignition ring is please? what size hammer do I use? (sort of serious cos I will have to do this myself as the car is immobile just now) ! Thanks !  :)
omegod
If you take the cowling off the ignition there is a black plastic circle around the barrel with a small box attached with a blue electrical connection, unplug the cable and the black plastic bit will pry off with a stout screwdriver , pop it off and put the new one on and connect. No hammer should be required at any point!!!!  New one is in the post  :y
BIZYWZD
You truly are a God of Omegas.  8)
Thanks again.
Quote from: BIZYWZD on 10 September 2016, 13:54:53
Thanks again.
No he's not.......he's a very naughty boy  ;D
zirk
Quote from: BIZYWZD on 10 September 2016, 12:57:24
Hammer, ? to remove a Immobilizer ECU,  and you thought Kwik Fit were Cowboys.  :-X
omegod
Quote from: STEMO on 10 September 2016, 15:13:33
Thanks again.
I'm always getting spanked .....and quite like it  ;D
BIZYWZD
#36
Next on my list.
The passenger side front central locking doesn't work.
How do I identify the problem?
sticky knob (steady... )  or a Servo or another ECU -bloody car has 100's of them !
Quote from: BIZYWZD on 10 September 2016, 22:33:11
Next on my list.
Might try the door solenoid first ::)
Shouldn't need a hammer either :-X
Kevin Wood did a great guide for replacing the microswitch in the servo. About 95% of the time, that cures solenoid faults.
johnnydog
My local scrappy charges a fiver for a door central locking solenoid. Changed several on different Omegas and never had a duff one yet. As you have to remove it from the car no matter which route you decide, I don't think it's worth messing about changing the micro switch IMHO for a fiver. And if you are unlucky enough to get one that is shot, then they will change it for another (they obviously mark them to stop the less honest returning the old duff one of course...)
Quote from: johnnydog on 11 September 2016, 20:30:33
Reason for replacing switch, is all used solenoids will likely have tired switches.  But for a quick fix, yeah, replace (if you can get that cheap), then refurb old one as a spare :)
If you refurb the motor it'll only cost you a couple of quid for the switch(es) and then you get one with a brand new switch rather than one that could already be quite tired, as said.
I don't think I've ever had one fail once it's been refurbed with a new switch, but all 4 of my locking motors failed quite early on with the original switches, which makes me wonder if the original motors had a dodgy batch of switches.
