Author Topic: Exterior B-Pillar Trim removal - how?  (Read 5280 times)
Diamond Black Geezer
    • & a silly coupe coming...
« on: 05 September 2016, 08:47:55 »
Need to swap my B-pillar trim. Anyone done it?
Being a bit swift jumping out yesterday, I think my belt loop must've caught the corner and snapped a chunk off!  :'(  :-[ Ah well, everything else on the car has been replaced, so might as well change this too!  :o
I've had a play and although it slides downward to remove, there's a clip at the top which I snapped off in doing so. It looks as it you either remove the gutter rail trim, then lever it up or out somehow to release this before sliding down, maybe. Can't find it anywhere on the web. I've got a spare awaiting on the spare Omega, but I don't want to snap this small internal clip off this one, too, in removing it.  Anyone any clue?
Omega VT3000
  • Essex
Re: Exterior B-Pillar Trim removal - how?
« Reply #1 on: 05 September 2016, 11:37:22 »
I haven't looked this up but if my memory serves me correctly, you slide it down about 1/2 inch and gently pull towards you but I am sure someone will be along with the right answer soon  ;)
« Reply #2 on: 05 September 2016, 11:42:01 »
That might do it, James, thanks. As I'd already rather skillfully snapped a corner off I was able to be a bit ham-fisted, and play about trying to remove it. That 'down a bit, then pull' method sounds logical. A bit like the door trims, sills, etc.
To be honest, I'm doubting anyone will know how on here, as you've have to be Lord High Emperor of the Morons to damage a flush-fitting piece of gloss plastic...like I did  8)!
shyboy
  • Southport, merseyside.
    • Mazda 6
« Reply #3 on: 05 September 2016, 12:06:23 »
I thought you knew everything!
Ah! You do, but you don't know that.   ;D
« Reply #4 on: 05 September 2016, 13:01:01 »
Haha. Nope, far from it. (unless you're speaking about Mr VT3000 above, who also has a very extensive knowledge about all things rwd and Vauxhall)
« Reply #5 on: 05 September 2016, 13:35:43 »
Open both doors, insert a modest flat blade between the gutter trim and the top of the B pillar trim and pry the top out 1/4". Then simply slide it down and off :y
Refitting is the reverse without the prying bit :y
« Reply #6 on: 05 September 2016, 13:57:42 »
Ahh, I see my missus' best butter knife is going to get put into service again!!  :y
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #7 on: 05 September 2016, 14:17:42 »
This set( LINK ) is very useful, why is probably how Snap-on get away with charging 10 times as much for it.
« Reply #8 on: 05 September 2016, 14:58:53 »
Much appreciated Nick, that's on my Xmas list, now  :y
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #9 on: 05 September 2016, 18:23:08 »
Looks very useful Nick, also this timing kit is cheap, do you know if it will do our V6's? http://www.rallydesign.co.uk/product_info.php?products_id=22091
  • Chatham, Kent
« Reply #10 on: 05 September 2016, 18:50:01 »
Here it is with a V6 locking kit:
It has the locking wedges for the cam pulleys, but not the gauge or crank tool which are the important bits. So unless you're intending to do a couple of engines at a time, it isn't a cheap way of acquiring a kit.
« Reply #11 on: 06 September 2016, 08:51:22 »
How odd, having never really noticed it before, it was only the other day I saw one of the above kits with the sliders/wedges, now here it is again. As you say, you need the other locking parts, too.
  • Chatham, Kent
« Reply #12 on: 06 September 2016, 11:40:22 »
It's been available from other sources for ages, but not at that price. I bought it when I was expecting to do a 2.2 last year, as it was only slightly more expensive than buying the VX only tools. I doubt I'll use any of the Japanese tools, but the Zetec ones will probably come in handy. As does this adjustable pulley-locking tool:
« Reply #13 on: 06 September 2016, 11:46:34 »
Well, she's had to take her nan into A & E so I don't suppose she's going to fancy pinging the B-pillar off the spare Omega (which is up her nan's drive)
Some people can be so selfish!  :D
Shackeng
  • Ramsbury
« Reply #14 on: 07 September 2016, 11:14:09 »
I thought it was too cheap to be useful. :( :y
