Author Topic: Replace NCDC 2013?  (Read 7110 times)
Re: Replace NCDC 2013?
« Reply #15 on: 13 September 2016, 18:46:40 »
OK, to clarify....
If all components stay together and are used, you don't need to do anything.
If that is not the case, it needs depairing, the screen and HU reconfiguring, then the relevant bits re-paired
johnnydog
  • Lancashire
    • 3.2 Elite sal & est x3!
« Reply #16 on: 13 September 2016, 21:44:26 »
That's all sunk in now thanks!
Next question - has anyone got an Elite estate aerial base from an NCDC 2015 that had the telematics setup that they would be happy to part with, or at least know the part number of one?
Not quite on enough posts to ask in Parts For Sale /Wanted!
Many thanks for the input - I know it must be quite annoying when people ask for clarification when you know all about these things, but in my case, when you don't........but thanks again.
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #17 on: 13 September 2016, 22:53:10 »
Why do you need one of them?
Ok, that was a joke. ;)
Might be worth checking youve got the correct phone aerial loom in there before you go too mad. ;)
johnnydog
  • Lancashire
« Reply #18 on: 13 September 2016, 23:15:15 »
Any pointers as to how I do that?
zirk
  • Epping Forest
« Reply #19 on: 14 September 2016, 08:46:07 »
Drivers Footwell (A Pillar is probably a good place to start), what your looking for is three coax cables, FM Radio, Probably Grey, thicker of the three cables, that will be there, GPS, probably Black, a thinner Black cable, that should be there if its a late Elite, and a GSM again probably Black thinner cable, may not be there, but might be if late Elite.
Some or all of the cables above maybe wrapped in a foam covering but the loom has connectors at the footwell which breaks the loom from the HU / Telematics to the footwell / the Aerial Loom, on the Estate, all three cables run to the Aerial Base / Whip on the Roof. You can get access to the Roof Aerial by partially dropping some of the rear Headlining.
You could also compare the cables from the donor car if it has Telematics fitted, at the A pillar foot well guessing the cable set up here should be the same whether Saloon or Estate, unless someone knows otherwise.
« Last Edit: 14 September 2016, 08:52:54 by zirk »
