seats
Started by pauls, 09 September 2016, 17:50:53
V8S
No worries.
If he doesn't come up trumps, how much are the pads worth to you? I'd obviously consider taking them out if it's worth my while.
Diamond Black Geezer
Not a lot, sadly! If it were fronts, because I need some because my seats are broken, then that would of course be different (and I've already got a pair of spare front seats) but I'm literally just 'modding' the rears, just to make my car a little bit unique, but it's not like I ever get rear passengers in, very often anyway. But I don't wantt o offer youa pittance for what could be a fair amount of time messing around. I'll get back to you on it, though. Much appreciated for the offer :y
Removing the cover to access the pads is simply a matter of unpicking the hog rings holding the cover on...
Not sure what it has to do with Pauls seats though :-\
Apologies, this thread has become hijacked (my doing) I just mentioned that was what I'd do with a rear bench, should a similar situation arise/had Pauls been cloth, then I'd be jumping at the chance.
As I've said, shame these can't be of use to someone.
Delroy47
If you still have these and will split I'd like the passenger seat as adjuster switch is broken on mine  :y
V8S
Which seats do you mean? Mine or Diamond's.
Funnily enough the plastic knob has broken on my passenger seat too. It still works absolutely fine but the knob isn't there. The one that makes it go up, down, forward, back.
Delroy47
Not quite sure which is which  But must be an Elite passenger seat as when my 86 yr old Pops gets in he has trouble adjusting the seat  :'(
Can't help you with mine, then, just to confirm. Spares car is leather MV6, so manual adjustment all the way. But eleccy ones come up fairly regular.  :)
Not actually sure if Paul has skipped these by now, or not? Not seen him on here for a while.
pauls
Quote from: Diamond Black Geezer on 30 September 2016, 09:19:37
Still Here :y
I have had a pm from a member on here, just waiting to see if he still wants them if not i will split them then skip the rest.
Ah, good good!
There was a mint FL Omega my mate was scrapping. FL Nocturno lue. Mint, I mean mint. He'd have liked to have kept it, I'd have liked to have bought it off him. And I could have had it for pennies. But, alas to become baked bean tins it went. Doesn't make it easier, I hate seeing decent stuff go in the bin, but if no-one wants it, that's it. (I posted the car up on here, incidentally, no takers) hope these go to good use  :)
Delroy47
All good, as long as it doesn't turn into a bun fight  ;D
Migv6 le Frog Fan
I quite like the idea of grey leather in my car as I think it would compliment the rubens red bodywork better then black leather does.
Problem is I would then need grey seatbelts, doorcards and probably other bits too, so realistically its probably a non starter.
Quote from: Migv6 on 30 September 2016, 20:24:19
Leave the rest of the trim/belts black and recover/swap the door card inserts and lower dash panels to match the seats :y
Alcantara would provide a tactile contrast
