Author Topic: How to test if the radiator cooling fans are not working with air con TD?  (Read 1693 times)
SR-71Blackbird
  • Watford
    • 2.5TD Silver Auto Elite
Hi all,
The cooling fan did not come on with the air con today so it was not cool.
Is there a way to check if the motor of the fans are ok or burned out? It worked fine yesterday.
Does the TD have a specific 2 radiator fans or is it the same as other 2 fan Omegas?
Thanks
Alex
frostbite
  • Roanapur City aka Skem
    • 00' e46 325i se
Could unplug the coolant sensor. Failing that the fans can be shorted to get then spinning although Ive never done it before, Im used to a viscous fan roar on a cold start
e46 325i se - 1.8vvti avensis liftback
