Pages: 1 ... 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 ... 27   Go Down
Author Topic: This Week in Wheeler's Workshop  (Read 244064 times)
0 Members and 3 Guests are viewing this topic.
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
Re: This Week in Wheeler's Workshop
« Reply #255 on: 26 June 2020, 17:01:52 »
I imagine it will still handle like an MGB though.
« Reply #256 on: 26 June 2020, 17:13:43 »
Front end should be lighter ;)
Migv6 le Frog Fan
« Reply #257 on: 26 June 2020, 17:25:53 »
Really ? V6 lighter than a B series four ? Even so, the handling was dire with S4 or V8, due to the suspension design being centuries old.
    • 530D M Sport, 330i Coupe
« Reply #258 on: 26 June 2020, 17:35:25 »
Looks great  :y
Lot of work gone into that installation.  :)
« Reply #259 on: 26 June 2020, 18:32:45 »
Upon investigation, there's not much in it... 181kgs for the 4pot boat anchor vs 190ish* for the V6 ;)
* The 3.0 V6 turbo version that SAAB used is 197kgs.
Migv6 le Frog Fan
« Reply #260 on: 26 June 2020, 20:33:00 »
It does look a lovely installation though.  :y Would be even nicer in a Chevette.  :)
456lbft
    • Omega MV6-Fred
« Reply #261 on: 27 June 2020, 09:05:41 »
V6 is shorter than a 4 pot too, and unusually narrow V angle helps a bit too as long as you don't have a steering box to get around...
Carlton 3.6 Track Car
Omega 3.2 MV6 Fred
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #262 on: 27 June 2020, 10:13:05 »
the problem with engine swaps in a lot of fifties cars(MGB underbody wasn't new) is that the front chassis rails sweep up and inwards to mount the suspension. That doesn't really matter with a tall, inline engine but is right where the exhaust manifolds need to be on a vee motor. DOHC heads make that worse, as do the very wide Rover heads - Rover V8s are only common swaps in the UK due to their ubiquity, they're actually long, tall wide, underpowered compared to their bulk, and not very durable. And the 'alternatives' were even worse; Essex V6 for example.
When comparing the weights, don't forget the gearboxes: four speed with an additional chunk of overdrive both in cast iron compared to a shorter aluminium cased five speed. Swapping the massive V6 flywheel four cylinder one would make another difference. Although we've fitted the back of the engine in the stock location, the front pulley is about where the front axle line lies. This changes the weight distribution, as the car currently sits higher than normal on its standard front springs.
MGB suspension is double wishbone front with decent geometry, and there's nothing wrong with parallel leaf springs. The biggest problem is that it's all a bit cramped under there. This car is intended as a GT, so with appropriate front springs, thicker oil in the front dampers and telescopic rears(Escort ones I bought by mistake 20years ago) plus 4pot calipers on bigger, vented discs(an off the shelf upgrade as Ian wants to keep the stock alloy wheels) it will be plenty good enough. The car's small size, light weight(even small modern cars are ridiculously heavy), impressive power to weight and torquey power delivery will make for seriously usable performance. If it were my car, I would have used a 2.2 four cylinder.
« Last Edit: 27 June 2020, 10:22:35 by Nick W »
456lbft
    • Omega MV6-Fred
« Reply #263 on: 28 June 2020, 22:24:41 »
speaking from experience, the Rover is a nightmare for making exhaust manifolds because the head face is vertical, not even slightly angled downwards.  So you have to start with a 135degree bend to tuck it into the block. These days we can bend them on a very tight radius with no kinking or loss in cross-section, but that certainly wasn't possible as easily back when I started in the eighties.  Triumph Stags with Rover engines in were a common swap back then. The Omega V6 in an MBG sounds much more sensible by comparison.
Omega 3.2 MV6 Fred
  • Online Online
« Reply #264 on: 29 June 2020, 15:38:46 »
Apparently the MGC handled even worse.
  • Chatham, Kent
« Reply #265 on: 30 June 2020, 08:20:02 »
there's not much MGB under an MGC.....
Front structure, gearbox tunnel, suspension and steering are all very different to accomodate the boat anchor masquerading as an engine. Supposedly, the press demonstrators had incorrectly inflated tyres for some reason; fixing that makes a big difference
456lbft
    • Omega MV6-Fred
« Reply #266 on: 07 July 2020, 14:46:08 »
Wasn't it an Austin Healey engine, iron head and all. I can hardly lift the head alone of one of them, and yet a bare rover V8 block and heads is easy (or was 10 years ago before bulging discs and sciatica..)
Omega 3.2 MV6 Fred
Keith ABS
  • Maldon Essex
« Reply #267 on: 07 July 2020, 19:55:34 »
Much nicer in a Manta Albs :y :y
Migv6 le Frog Fan
« Reply #268 on: 07 July 2020, 21:22:28 »
Nah, Manta always looked a bit big and cumbersome to me compared to the Chevette. All personal preference of course.
I need to speak to you soon Keith about hire of ABS cam locking kit. :y
  • Chatham, Kent
« Reply #269 on: 08 July 2020, 09:32:30 »
it was just BMC's six cylinder engine as used in their big cars and trucks, but in a slightly higher state of tune.
The twin-cam MGA engine would have made the MGB a much better car, if the design hadn't been so crap. Something that Triumph continued with their slant engine family(which includes the Stag V8) and especially the Sprint cylinder head. If those had been better designed and engineered(angled head bolts for instance), BL would not have been reliant on the B-series, Rover V8 and Triumph six throughout the seventies.
Pages: 1 ... 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 ... 27   Go Up
