Author Topic: Would a failing/failed rev counter cause the Auto Transmission Check light?  (Read 1516 times)
SR-71Blackbird
  • Watford
    • 2.5TD Silver Auto Elite
Hi guys,
Progressing with my bad rev counter issues.
Now it does not work from cold for about 20 mins and then starts to jump around.
Could a bad rev counter in the dashboard be the cause and could this cause the Auto transmission check light to come on that is happening to the car?
I have taken the dashboard/dials section out etc with the guide, then put it back, no change. So i can replace if that is the issue.
What do you think?
Thanks
Alex
Doubt it.
But you could drive around without a dash for an hour, see if gearbox goes into limp.  Obviously, you'd have to reset the airbag light afterwards though.
