Pages: 1 [2] 3  All   Go Down
Author Topic: Oil Extractor  (Read 9540 times)
Re: Oil Extractor
« Reply #15 on: 12 September 2016, 14:16:13 »
Ordered one Andy uses, as I want to get an oil change done soon ish. As I'm going to be putting some miles on it soon  :)
Re: Oil Extractor
« Reply #16 on: 12 September 2016, 15:51:57 »
50p for a suitable block of 2"x4" :-X
You can even notch it if required...
Re: Oil Extractor
« Reply #17 on: 12 September 2016, 15:52:57 »
assume this is for other thread  :D
Re: Oil Extractor
« Reply #18 on: 12 September 2016, 15:55:17 »
assume this is also on the other thread  :D
Fixed for accuracy  :y
Re: Oil Extractor
« Reply #19 on: 12 September 2016, 16:09:06 »
In December with it freeing outside, this method does appeal. I could just about get nose of the car in the garage, meaning dry/warm for oil change.
So change the oil in the Autumn then.
If it has a drain plug, I'd use it.
TBH, my experience of pumps has never been worth the effort.
Re: Oil Extractor
« Reply #20 on: 12 September 2016, 16:47:01 »
Hunting in the garage I found a load of 2x4 I forgot about, just need to notch it and make a rubber patch of some kind
Re: Oil Extractor
« Reply #21 on: 12 September 2016, 16:59:40 »
Would an old cut-off of carpet suffice?  Glued and screwed to wood if reqd?
Re: Oil Extractor
« Reply #22 on: 12 September 2016, 17:08:56 »
Need to do some digging around, I won't need the car mats in the 2.2 any more  ::)  :D
Re: Oil Extractor
« Reply #23 on: 12 September 2016, 18:25:41 »
Only if it's shagpile!  ::)  Tunnie's new baby must be comfortable even with it's legs in the air!  ;D
Re: Oil Extractor
« Reply #24 on: 12 September 2016, 18:28:59 »
The car or that thing that calls me Daddy?
If it's the latter she is nearly 2 and half now.  :o
Re: Oil Extractor
« Reply #25 on: 12 September 2016, 18:33:42 »
Don't think a 2 1/2 year old could be described as a new baby.  ::)   :-\
Anyway it's about time you created a little brother or sister for her, and now you have a shiny new car to cart them around in, you've no excuse!  :D  ;D
  • Online Online
Re: Oil Extractor
« Reply #26 on: 12 September 2016, 19:17:10 »
Would the pipe naturally sit right at the bottle? Not idea how rigid pipe is TBH.
Remember the lace curtain wire thingies ..... generally white with a screw in eye at each end? It's the same ast that .... ie flexible but rigid enough to insert down the dip stick tube  :y
Re: Oil Extractor
« Reply #27 on: 12 September 2016, 22:53:16 »
Now you've gone and done it...
Be twins next, which will see the four seat, four door coupe screwed :D
  • Online Online
Re: Oil Extractor
« Reply #28 on: 13 September 2016, 00:20:17 »
Bloody hell ...... and it was only 5 mins ago that Tunnie was a spotty student!  ;) ;)
Re: Oil Extractor
« Reply #29 on: 13 September 2016, 09:43:54 »
Hell no. The 3.2 will be flogged and Galaxy purchased instead!
Pages: 1 [2] 3  All   Go Up
