Author Topic: How to change my Elite info screen from German back to English.  (Read 6499 times)
ted_one
As above,2001 Elite 3.2, I must have had some sort of electrical glitch,as all info is now in German,has anyone any ideas how to change it back to English. TIA :y
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: How to change my Elite info screen from German back to English.
« Reply #1 on: 12 September 2016, 18:15:51 »
It's noted how you voted in the referendum, and is preparing to be exiled back home ;D
« Reply #2 on: 12 September 2016, 18:21:09 »
Go BC
1) einstellunge
Press OK
2) Systemeinstellunge
OK
3) bedientuhrung
OK - 2nd from top
« Reply #3 on: 12 September 2016, 18:50:14 »
Learn Deutsch!  :P
ted_one
« Reply #4 on: 12 September 2016, 19:19:56 »
Many thanks Tunnie....the voice of reason and common sense :y  Nick W and Sir Tigger....just go and sit on the naughty step UFN!!  :)
« Reply #5 on: 12 September 2016, 20:35:44 »
Did the battery go flat?
You can get it to default to English in such circumstances, but needs a Tech2.  GM couldn't be arsed to do that in the factory.
« Reply #6 on: 12 September 2016, 20:39:30 »
 ;D ;D ;D :y
ted_one
« Reply #7 on: 12 September 2016, 21:29:15 »
No problems with the battery,co incidently it happened when the transmission selector locked itself in park.I still have the selector problem and at the moment I'm releasing the selector manually,as the car is going up to Serek next week for a bit of investigation work re the foot brake switch.Will definitely try Tunnies tip. ;)
« Reply #8 on: 13 September 2016, 16:08:44 »
Hmmm, for it to just lose its settings for no reason is slightly concerning.  Any other symptoms with NCDC or display?
ted_one
« Reply #9 on: 13 September 2016, 20:30:55 »
No other symptoms/warnings with the car at all other than the occasional car with the spanner icon coming on and then disappearing, and just having to be a part time gynecologist and having to stick my fingers into the internals of the selector mechanism to move the flap to allow drive etc to be selected.I had the car out over the weekend and gave it a 200 mile workout without problem.But definitely a problem with the brake pedal switch is number one and the German hyroglifics are just a bit of a nuisance. :-\
« Reply #10 on: 13 September 2016, 20:33:19 »
Lets hope that's the end of the screen language problem then :y
ted_one
« Reply #11 on: 13 September 2016, 20:37:20 »
Meant to take a look at it today but this retirement thing is not what's it cracked up to be,the to do list never gets shorter :o
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #12 on: 13 September 2016, 21:00:46 »
If tour talking about the NCDC Screen, one of mine has done this twice now in 6 years, no reason whats so ever, no idea ¯\_(ツ)_/¯
« Reply #13 on: 13 September 2016, 21:02:24 »
And didn't depair, or screw up fuel computer?
zirk
  • Epping Forest
« Reply #14 on: 13 September 2016, 21:06:30 »
Nope, first time was after a lunch break, second time was when popping to the shops, so would have been left along all but 3 mins.
The only common denominator is it happened after a engine restart.
