Author Topic: Cruise control  (Read 3259 times)
bob.bowring
  • GILLINGHAM KENT
    • omega CD 2.2ltr auto
Cruise control
« on: 19 September 2016, 20:22:07 »
Can anyone help I have only had my car for 4 days does the Omega have a screen read out of the speed set with the cruise control my Lexus had a read out many thanks
RJB
Re: Cruise control
« Reply #1 on: 19 September 2016, 20:30:39 »
No, no dash readout or light  :y
bob.bowring
  • GILLINGHAM KENT
Re: Cruise control
« Reply #2 on: 19 September 2016, 20:46:33 »
Many thanks for that Tunnie all he best
RJB
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Cruise control
« Reply #3 on: 19 September 2016, 22:57:42 »
Apart from the Speedo, that will be a good indication on what the Cruise control is doing.
frostbite
  • Roanapur City aka Skem
    • 00' e46 325i se
Re: Cruise control
« Reply #4 on: 20 September 2016, 18:08:32 »
I have to use a satnav for correct speed  :( my speedo is out 5-6mph after 40mph
e46 325i se - 1.8vvti avensis liftback
Re: Cruise control
« Reply #5 on: 20 September 2016, 18:46:00 »
Stock tyre size?
frostbite
    • 00' e46 325i se
Re: Cruise control
« Reply #6 on: 20 September 2016, 19:06:32 »
They are  :y 205-65-15 for now, then they'll be 235-45-17 again still within range
my '95 3er bmw was also out but further up at 75mph, the merc, volvo and old omega were perfect
zirk
  • Epping Forest
Re: Cruise control
« Reply #7 on: 20 September 2016, 19:16:10 »
The V6's read about 3 mph higher around the 70 mark, cant remember what the 4 pots do but shouldn't be as far out as your quoting.  :-\
frostbite
    • 00' e46 325i se
Re: Cruise control
« Reply #8 on: 20 September 2016, 19:55:15 »
TBH its not a problem it just means I wont get into trouble  :y
I set the cruise at 70 and the speedo reads about 76ish
bob.bowring
  • GILLINGHAM KENT
Re: Cruise control
« Reply #9 on: 20 September 2016, 22:46:48 »
Many thanks to everyone for answering
RJB
Diamond Black Geezer
    • & a silly coupe coming...
Re: Cruise control
« Reply #10 on: 21 September 2016, 09:23:44 »
My TD was pretty far out- maybe 5mph at 40, thereby 10mph at 80 (not that it could get there)
Pissy is very close, 1-2 at 30mph, maybe 3-4 at 70mph.
Re: Cruise control
« Reply #11 on: 22 September 2016, 19:14:33 »
All Omega speedos I've (electronically) tested at between 2-3mph out over the whole range up to 140mph.
So if reading anything else, wrong speedo config programmed, faulty speedo, or wrong tyre size.
Re: Cruise control
« Reply #12 on: 22 September 2016, 21:21:26 »
Chances are then that clocks have been replaced with a V6 one then :-\
