Author Topic: VW TSI Blue Motion 1.4  (Read 12679 times)
Re: VW TSI Blue Motion 1.4
« Reply #30 on: 25 September 2016, 23:03:08 »
Food for thought indeed, but there appears to be a miss understanding with my commute, I don't go any way near central London.
Don't go any way near current emmisons zones  :y
Even the proposed ultra low one is still miles and miles away, so I'm not too worried  :)
Actually you do ;D
Assume you work at HQ, Brentford... This is well inside the current Low Emission Zone which encompasses the whole of Greater London. ::)
This is currently free for cars and small vans, but not for trucks and buses.
The draconian Ultra Low Emission Zone is actually the Congestion Charge area, in which ALL fossil fueled vehicles will pay.
« Reply #31 on: 26 September 2016, 14:40:17 »
My 2.0 TDi is "Blue Motion" some of them in the stats, you have an "AdBlue" tank of fluid in the boot, which reduces the emissions. It sprays fluid into the exhaust, luckily we don't get that here in the UK
Which is part of the reason VW cant meet emissions with a software mod for a number of their cars here...............
« Reply #32 on: 26 September 2016, 15:04:52 »
Keep meaning to contact VW and see if mine was part of the emissions gate scandal, but as it's working fine and running well I don't think I will.
« Reply #33 on: 26 September 2016, 15:28:40 »
At that age it will be. :y
They mucked about with lots of things the key one being EGR which impacts the NOx.
« Reply #34 on: 26 September 2016, 15:30:33 »
Thanks  :y
Seeing how easily they get clogged, I'd like to clean this, but not sure I can do it myself.
Anything else I should look out for/service on this engine in particular? I know you don't rate them as much as the old 1.9 PD units  :)
« Reply #35 on: 26 September 2016, 15:40:57 »
There not nearly as good as the 1.9 PD, for me they are a pretty poor unit and not good if not serviced regularly from day one.
EGR valve is not to bad to do, my preferred cleaner is oven cleaner as carb cleaner struggles with the baked carbon.
« Reply #36 on: 26 September 2016, 15:45:00 »
Service interval states every 20k, but I can see it's be serviced (oil change) every 17k. With air here and there. Best I can expect from dealer servicing I guess. I plan oil changes every 5k, for next 15k - then stretch them to 10k
« Reply #37 on: 26 September 2016, 16:10:13 »
Why stretch them ???
Every five will keep it sweet, hopefully without the need for top ups in between. Eeking the services out will probably cost you an extra two litres every change with top ups... (VW do say that a litre every thousand km is acceptable behaviour).
Also, when is the cambelt due? 60-80k miles depending on who you ask... VW say 60, Skoda say 80, Seat didn't know when asked so suggested 70k in writing. Critical for water pump to be done at same time as it's belt driven... but importantly not on the service schedule :o
If cambelt has been done without the water pump, it will probably start leaking around 100k, requiring a premature belt change.
« Reply #38 on: 26 September 2016, 16:22:07 »
I'll see how oil usage goes, also see how smooth oil feels if it's picking up too much soot.
Checked cambelt as lots of numbers flying around, rang VW and quoted my registration. Also rang 2 different dealers to confirm, they all stated 140k and 5 years which ever is first.
As it's 3 years old, I'll change belt and pump late next year  :)
« Reply #39 on: 26 September 2016, 16:25:04 »
Fair dos :y
Keep an eye on the water pump though ;)
« Reply #40 on: 26 September 2016, 16:27:01 »
Will do  :)
But I need to find the water pump  :-[
Being WWD engine points the other way  ::)  ;D
« Reply #41 on: 26 September 2016, 16:29:51 »
Think it's to the left of the block at the 'front', and down from the thermostat casing iirc :-\
« Reply #42 on: 26 September 2016, 16:38:53 »
Whats the wanky DSG service interval these days, it used to be 40k miles
« Reply #43 on: 26 September 2016, 16:40:24 »
I specifically avoided DSG, mine is a traditional manual  :)
But yes, think it's 40k
« Reply #44 on: 26 September 2016, 22:32:26 »
or "Doesn't Sodding Go", as was the case with my brother's Passat. ::)
Pages: 1 2 [3] 4  All   Go Up
