Author Topic: Who on here has .............  (Read 3047 times)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« on: 27 September 2016, 15:44:11 »
Eibach springs fitted to a facelift estate ?
Need a measurement from the top of the tow bar ball to the ground if possible please  :-\
No point pishing about with a tape measure on my Mv6 and taking away 15mm because my springs have done 150K and will have stretched / sagged out of proportion  :(
Trying to work out if I can still pull the pikey van with Eibach lowering springs  :-\
Diamond Black Geezer
    • & a silly coupe coming...
Re: Who on here has .............
« Reply #1 on: 27 September 2016, 15:51:16 »
In theory this is no chuffing use to you at all, but ... I can tell you what Pissy's ride height it later on, knowing for a fact she's sitting higher on MV6 springs, than she used to on her old sagged original springs. And she used to tow. (including a 1300kg Royale on a trailer)
The towbar's in le parent's back yard now, being lovingly converted to iron oxide.  :)
« Reply #2 on: 27 September 2016, 16:35:14 »
Do you still have self levelling fitted?
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #3 on: 28 September 2016, 11:43:18 »
Nup
Mv6 at the front
Standard size, heavy duty springs at the rear.
Different rear springs fitted to even out the extra weight of the LPG tank in the spare wheel well.
Car sits perfect with a full tank of LPG and 1/4 tank of petrol.
B4's all around.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #4 on: 29 September 2016, 11:10:51 »
Anybody help on this ?
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #5 on: 01 October 2016, 16:02:51 »
Probably no help but my 2.6 ball is 40mm ground to top of ball.
« Reply #6 on: 01 October 2016, 18:26:19 »
Are you sure that it's the correct way up... :D
Ball should point up ::)
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #7 on: 01 October 2016, 19:52:06 »
Sorry don't quite get that :-[
« Reply #8 on: 01 October 2016, 20:20:55 »
Guess you meant 400mm ;D
40mm is less than 2"...
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #9 on: 02 October 2016, 15:19:05 »
Sorry Doctor Yes my car is a little low at the back :y
