Author Topic: OEM vs pattern  (Read 6808 times)
Diamond Black Geezer
    • & a silly coupe coming...
Re: OEM vs pattern
« Reply #15 on: 03 October 2016, 09:30:23 »
I don't know how many people actually wanted a Smart Roadster/Coupe; going by sales, not that many apparently, but I was one of them people, I woudn't mind one, one day. :)
annihilator
  • Wirral
    • Omega Tourer V6
Re: OEM vs pattern
« Reply #16 on: 03 October 2016, 09:38:14 »
Just don't would be my advice especially if it has the MHD engine with a design fault that throws off the poly belt that causes the engine to fry in about 10 mins if not spotted.
John.
Re: OEM vs pattern
« Reply #17 on: 03 October 2016, 10:47:49 »
Biggest problem with them is that they're not water tight. Water will get in by the wiper motor & fry the SAM (main ECU) and they're £600 to replace. MB spent a fortune on warranty work tryingto keep water out of them before they pulled the plug on them. Mine is now mostly dry.
They're a brilliant car to drive on the twistys ...... but they're not fast, just feel it when you just turn into a corner at what would be silly mph in most other cars.
Re: OEM vs pattern
« Reply #18 on: 03 October 2016, 10:49:03 »
John.
I think MB are on to the 3rd mod to the poly vee belt tensioner  ::)
2boxerdogs
Re: OEM vs pattern
« Reply #19 on: 04 October 2016, 15:35:59 »
Always use OE parts on all our vehicles, may cost a little more but all receipts kept in a ring binder for each car looks impressive when selling, I think I like to see a good traceable service history  just a bit OCD on my part
Re: OEM vs pattern
« Reply #20 on: 04 October 2016, 15:51:04 »
Had a dig, a rough list of what I've used pattern v OWM is as follows...
'Pattern'
Coil pack
Wishbones pattern metalwork (see below)
Powerflex Poly front bushes
ATP droplinks, track rods
Bilstein shocks all round
Bosch HT leads
Brake hose FOS
Light bulbs
Front brake shield screws (stainless steel)
Exhaust head shield nuts/bolts (stainless steel)
HEL Stainless steel caliper banjo bolts
Drive Belt
PAS oil
Castrol Gearbox oil
OEM / Vx
ball joints
Wishbones - (Vx ball joints and rear bush)
All filters, Oil, air, pollen
Oil
Coolant
water pump
Brake pads F and R
Wiper blades
HBV
Battery
Thermostat
Coolant temp sensor
Rocker gaskets
Manifold gaskets
Gearbox gasket (leaking, I might add!)
Various breather o-rings
Brake fluid
plus god knows what else!
« Last Edit: 04 October 2016, 15:53:46 by Diamond Black Geezer »
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
Re: OEM vs pattern
« Reply #21 on: 04 October 2016, 17:05:39 »
WOT no crank Sensor? ::) ;D :y
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: OEM vs pattern
« Reply #22 on: 04 October 2016, 17:34:36 »
How about a rather different list?
In the almost six years I've owned my car, I have replaced:
Front wishbones, struts, top mounts and bearings, droplinks, trackrods, steering idler and centre track rod.
Rear shocks and subframe mounts
Timing belt, waterpump, HBV, oil, oil/air/pollen/fuel filters, plugs, coil pack, crank sensor, plug leads, N/S radiator hose, all of the gaskets from the head gaskets up, entire exhaust including used 3.2 manifolds but excluding the O/S cat, trans fluid and filter, thermostat, oil fliter adapter, ABS ECU/valve block(the only  other used part on the car), battery, power steering hose, and A/C high pressure valve, all the exhaust studs bolts and nuts,
Rear brake discs/pads/handbrake shoes and cable, one rear wheel bearing.
Headlight adjusters
Trim clips for the rear quarter/bumper trim
All three wiper blades
Of those parts, the cranksensor, radiator hose, oil filter adapter and trim clips were bought from my local dealer; the Elite rear shocks are genuine GM(still in the boxes) bought off Ebay for £100; and I was given the A/C valve. Everything else is pattern, the plugs and coil pack are the only parts where I specified a brand: they're Bosch.
« Last Edit: 04 October 2016, 17:37:32 by Nick W »
Re: OEM vs pattern
« Reply #23 on: 05 October 2016, 09:38:47 »
Haha, she's had one in the past, but not personally by me. It's on the wants list.
Nick, that's a good list  :y
