Author Topic: Handbrake  (Read 8576 times)
steve6367
Re: Handbrake
« Reply #15 on: 03 October 2016, 23:44:03 »
On both of mine I've simply tightened the cable when the MOT says excessive travel. 5 minute job but I imagine there a reason using the star adjusters is better?
Steve
Re: Handbrake
« Reply #16 on: 04 October 2016, 02:40:18 »
Steve
The star adjusters actually allow you to adjust the hand brake mechanism.
Simply stretching the slack out of the cable achieves nothing constructive...
annihilator
  • Wirral
    • Omega Tourer V6
Re: Handbrake
« Reply #17 on: 04 October 2016, 08:50:22 »
except making the handbrake hold and getting a MOT pass.
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Handbrake
« Reply #18 on: 04 October 2016, 08:59:50 »
But it is a short-term fix that stretches the cable, and is harder to do than the long established procedure.
annihilator
  • Wirral
    • Omega Tourer V6
Re: Handbrake
« Reply #19 on: 04 October 2016, 09:55:51 »
Didn't say it was long term but will get you a mot pass and what if you've fitted new everything surely with unworn discs and shoes there isn't any wear to adjust.
John.
Re: Handbrake
« Reply #20 on: 04 October 2016, 13:46:56 »
John.
In which case, why would you not set each side correctly on reassembly... ::)
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
Re: Handbrake
« Reply #21 on: 04 October 2016, 15:56:16 »
I hate to shout, but can you not hear the underlying message in these posts?.....
DO IT PROPERLY!
Ron.
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
Re: Handbrake
« Reply #22 on: 04 October 2016, 17:24:01 »
Maximum leverage is achieved when the cable is at right angles to the brake operating lever. This is achieved when the star adjuster is adjusted so that brake is hard on after minimum movement. If the cable is tightened on a worn brake this leverage is lost.
There is a 4:1 leverage at lever end inside the brake, so long as the ingenious pivot arrangement is not rusted solid, as often occurs after 10 years of neglect. Cure is to remove the drum and free it. A well adjusted free handbrake is powerful and light to apply. A rusty h/brake adjusted at cable front end may feel solid, but will be a lousy brake.
powerslinky
Re: Handbrake
« Reply #23 on: 04 October 2016, 17:29:50 »
John.
Not if the handbrake is not fairly equal on both wheels .No amount of cable adjusting will rectify that. Common fault is that one side self adjusts & the other does not. It won't "should not" pass if too far unbalanced on the testers   brake test  "dials".
Surely if you are fitting new discs & shoes you would be setting up correctly anyway ?  :-\
« Last Edit: 04 October 2016, 17:34:35 by Essex Big Al »
annihilator
  • Wirral
    • Omega Tourer V6
Re: Handbrake
« Reply #24 on: 04 October 2016, 18:10:38 »
what a kerfuffle, you lot are so easily wound up  :-*
am I bovvered  ;D
powerslinky
Re: Handbrake
« Reply #25 on: 04 October 2016, 18:31:46 »
am I bovvered ;D
Straight out of the Saff'end Concise Dictionary that word . . ;D ;D ;D ;D
steve6367
Re: Handbrake
« Reply #26 on: 04 October 2016, 20:45:31 »
Well good news is it did get me a MOT pass on both and took 5 mins on each  :y
I will do it properly - but I didn't have time to strip the back brakes to get the pass.
The post about mechanical advantage makes good sense, I had not really seen what was being adjusted before.
Re: Handbrake
« Reply #27 on: 06 October 2016, 10:53:05 »
The maintenance guide coves everything you need for a proper service and setup
steve6367
Re: Handbrake
« Reply #28 on: 07 October 2016, 15:46:53 »
Thank you - another job for the list  :y
