Author Topic: Key fob for y reg 2.6 estate ?  (Read 2458 times)
powerslinky
« on: 04 October 2016, 19:22:12 »
hi all
         "new"  Y reg 2.6 estate  came with 2 very good condition keys/fobs . . but . . .
They are only 2 button ones  . . .open    & lock :-\
Should they be 3 button ones for that year or do estates only have 2 button fobs?
This is my first estate  . . .so not sure .
Tailgate locks & unlocks with the doors , but it seems there may be a problem with the alarm .
When locking with the fob the alarm button red light in the centre by the HU flashes rapidly & constantly.
Been locking car by open back door method until I can find out more  :-\ :-\
Any advice from you chaps ? :y
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Key fob for y reg 2.6 estate ?
« Reply #1 on: 04 October 2016, 19:30:40 »
Estates are only 2 button remotes, as the boot release isn't electric.
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #2 on: 04 October 2016, 19:43:46 »
hi all
2 buttons as no boot to open, different battery as well from memory.
you can set the tailgate to unlock or not with the fob by setting the key to the correct position in the rear keylock, you can also open the tailgate with the key without unlocking the rest of the car or setting the alarm off, have a play.
« Last Edit: 04 October 2016, 19:48:58 by zirk »
powerslinky
« Reply #3 on: 04 October 2016, 19:47:26 »
OK thanks Nick , thanks Chris . . . correct ones then  :y      This car DOES have a boot release button in the centre
console . . but it does not work . . . . which would make sense if boot release is not electric  ::)
But at least we cleared up the fob  issue :y :y  will have a play with key in the tailgate & the alarm  :y :y
« Last Edit: 04 October 2016, 19:51:59 by Essex Big Al »
zirk
  • Epping Forest
« Reply #4 on: 04 October 2016, 19:51:37 »
OK thanks Nick , thanks Chris . . . correct ones then  :y      This car DOES has a boot release button in the centre
console
Shouldn't have that.  see above post re open tailgate with key.
powerslinky
« Reply #5 on: 04 October 2016, 19:53:41 »
console
[/quote]Shouldn't have that.
Will that switch  cause an electrical problem ?  as guessing probably just a blank should be in that space? :-\
zirk
  • Epping Forest
« Reply #6 on: 04 October 2016, 19:58:15 »
console
Not sure if Im honest, the button is normally blanked off as you say, sounds like its been messed with, cant remeber what all the flashing means now, probably in the Manual somewhere. Could be its throwing an Alarm Fault, what happens when you deadlock it with te Fob (double press).
Also check the rear side window alarm sensors are there and intact.
« Last Edit: 04 October 2016, 20:00:22 by zirk »
powerslinky
« Reply #7 on: 04 October 2016, 20:07:31 »
 2 window alarm sensors each side from memory . Will have a check up after work tomorrow afternoon.
Will also check the deadlocking .  Will also check out the owners manual regarding setting & alarm operation
Thanks Chris  :y
